2.7 3rz supercharger kits
Discussion in 'Performance and Tuning' started by smmarine, Mar 14, 2016.
  1. May 2, 2016 at 10:25 AM
    #61
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Thanks. Do you know of any other forums out there where there are used parts I could find?
  2. May 2, 2016 at 11:33 AM
    #62
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Custom Tacos perhaps.
  3. May 2, 2016 at 11:54 AM
    #63
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Been a while since Ive been on there but there was always a turbo setup for sale. Ozboost in Australia exports a kit too btw.
    http://www.ozboost.com.au/
  4. May 3, 2016 at 10:22 AM
    #64
    boostedka
    James
    NM
    Does anyone use Journal Bearing turbos anymore? Seems like most people are recommending BB but those things are pretty expensive!
  5. May 3, 2016 at 10:39 AM
    #65
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I have two journal bearing turbos and one very fancy ball bearing turbo.
  6. May 3, 2016 at 11:29 AM
    #66
    boostedka
    James
    NM
    What journal turbos do you use? I've only come across garret GT and T series. WHere else should I be looking? THanks for the help
  7. May 3, 2016 at 11:44 AM
    #67
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Garrett, Precision, Turbonetics.Possibly Borg Warner.
    I recommend Garrett and Borg Warner as the premier choices.
  8. May 3, 2016 at 1:12 PM
    #68
    boostedka
    James
    NM
    sweet. Thanks for the help. I may be Pm'ing you as well later
  9. May 3, 2016 at 1:12 PM
    #69
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Deal.
  10. May 21, 2016 at 6:13 AM
    #70
    smmarine
    smmarine [OP] Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
  11. Jun 12, 2016 at 4:11 PM
    #71
    smmarine
    Melbourne FL
  12. Jun 12, 2016 at 4:33 PM
    #72
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  13. Jun 12, 2016 at 5:22 PM
    #73
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  14. Jun 12, 2016 at 5:24 PM
    #74
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Torspd[QUOTED] likes this.
  15. Jun 12, 2016 at 5:54 PM
    #75
    smmarine
    Melbourne FL
    So which kit should I get. I think a turbo would be better on mpg then a supercharger
  16. Jun 12, 2016 at 5:56 PM
    #76
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Turbo is always better than S/C. Just more complicated. I like the OZ kit but the LCE comes with a better turbo. IMO, I'm edging to the Oz but I think both will put a smile on your face.
  17. Jun 12, 2016 at 6:20 PM
    #77
    smmarine
    Melbourne FL
    I looked at the LCE kit. Doesn't seem that complicated. Just a bit lore work as far as getting oil to the turbo
  18. Jun 12, 2016 at 6:47 PM
    #78
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Getting the oil drain is the most complicated part of the whole process. You have to drop your diff to remove the oil pan, clean it, drill it, weld it, then put it all back together again. I don't know how the 2nd gen is but the 1st gen was a bitch to drop the front diff.
  19. Jun 12, 2016 at 6:55 PM
    #79
    boostedka
    James
    NM
    Check out the koracing kit as well. Build time can take a little while depending on how backed up they get, but I think it's worth it if you're looking at a bolt on application. I was looking into this set up but decided just to piece together a custom set up instead.
  20. Jun 12, 2016 at 7:16 PM
    #80
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Simplicity and durability. The key factors to go for.
    MetalRoofer33 likes this.
