2.7 4 cyl guys... Needing some input.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kuneff, May 19, 2011.
  1. May 19, 2011 at 7:50 AM
    Kuneff
    Kuneff [OP] Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    I have a leaky oil pan seal. I was considering changing the timing chain and stuff when I pull the oil pan off. I have no way of knowing if the milage is correct on the truck since it was a basket case of parts.
    Any thoughts on how often that stuff needs changed? Anyone know what the measurements should be for the chain to know if it is stretched too much?
  2. May 19, 2011 at 8:23 AM
    JohnnYp
    JohnnYp Member
    Arizona
    98 SR5
    throttle body spacer k&N cold air intake stage 2 clutch kit Gibson cat back exhaust kit bed liner and rocker panel lined
    the timing components are designed to last the life time of the engine......says Toyota
  3. May 19, 2011 at 8:27 AM
    cab4you26
    cab4you26 Well-Known Member
    Corey
    VA
    97 Tacoma, 5spd 2.7L
    Wheelers Offroad black steel wheels, 12 disc changer, spray in bedliner, Black UWS toolbox, Kelly Safari TSR's, Dynomax Super Turbo
    You said the motor was apart of a basket case of parts, so is the motor in the truck? or out of the truck?
    The 2.7 has 2 timing chains. One is for the actual timing (long one) and the other is for the balance shaft (shorter one). If the motor is in the truck it's going to be a PITA for you. The 4wd is going to have to be dropped, all the accesories come off, etc etc. I have some pictures of mine with all new chains, guides, and tensioners but I'll have to put it up when I get out of school. I pulled the motor out of my truck to do this, but the rear main seal was leaking so that was replaced as well. You also mentioned the oil pan is leaking. Are you positive it's the oil pan? Where is it leaking? It's possible your rear main seal could be leaking, too. In that case, if the motor is in the truck, it would more than likely be easier for you to pull the motor.
  4. May 19, 2011 at 8:41 AM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    Engine is in the truck. the truck itself was a basket case. The front end of the oil pan seal is where its leaking... About the front 1/3 of the pan.
    I was looking on alldata and it showed you can drop the pan without pulling the engine. Unbolt it, and that will allow you enough room to unbolt the oil pump pick up tube. remove the pump pick up and then the pan will slide out.
    Does that sound correct???
  5. May 19, 2011 at 8:56 AM
    cab4you26
    Corey
    VA
    Okay then your rear main isn't a problem.
    As for removing the pan in the truck I really don't know how do-able that is. The oil pick-up is bolted to the front cover if I remember correctly. I removed the oil pan out of the truck so it was much easier for me. I do remember the gasket was a pain and it took some prying to break it loose. I'm sure it's possible to get it out with it in the truck, but it'll be a time-consuming task at the least. I didn't use a gasket when I put it back together just a crap ton of RTV.
  6. May 19, 2011 at 9:06 AM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    All it takes is formagasket to fix it. Put it on and let it sit for at least 12 hours.
  7. May 19, 2011 at 12:07 PM
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    My truck had 170K when I changed mine. There was very little wear on the plastic parts. They hold up really well. The entire engine had very little wear. It blew my mechanic away. We changed all of the seals and did a head gasket job.
    You should be okay...
  8. May 19, 2011 at 6:44 PM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    just gunk that stuff right over the leaking gasket??? Doesn't seem like that would be a good fix.
  9. May 21, 2011 at 11:50 AM
    SRQ TACO
    Damon
    Sarasota, Florida
    No you pull it off remove the old gasket with a razor blade untill its raw metal and no gasket is left. Run a thick bead of permatex gasket stuff around it and put it back on. But you have to let it cure for 12 hours before you put oil back in it and start it.
