2.7 CLutch whine
Discussion in '4 Cylinder' started by altitan, Nov 9, 2012.
  1. Nov 9, 2012 at 2:34 PM
    altitan
    altitan [OP] Member
    Blountsville AL
    Prerunner SR5
    Ok guys did some searching around and couldnt find any previous discussion on this. I have a 2006 2.7L Regular Cab Prerunner with a three inch lift and 33s. In the last few weeks ive started noticing a noise, it only happens when the clutch is pressed, it sounds just like a wore out power steering pump whine, but like i said it is only whith the clutch pressed, also it moves with the rpms of the engine, the higher the rpm the louder the whine... any Ideas? ive seen plenty of threads on clutch noises but all of them the sound went away with the clutch pressed.. the clutch has always slipped a little bit when starting on a hill and the lift and tires made that slightly worse..
    Any thoughts or ideas would be greatly appreciated
  2. Nov 23, 2012 at 7:35 PM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    You are most likely looking at the release bearing or "Throwout" bearing. It is under load when your clutch is depressed, hence the much louder noise at that point. Do some searches on here about throwout bearing and clutch noise and you will find reams of threads.
  3. Dec 9, 2012 at 3:46 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    Black Taco '12 4x4
    Delay wiper mod. "Access" Tonneau cover. BedMat.
    I Concur...... I'd also suspect the throw out bearing. As for the slipping clutch - I'm not sure if there is an adjustment for the clutch play - but I think if it's too tight it forces the throw out bearing to constantly give pressure to the pressure plate - causing possible clutch slip under heavy load and premature throw out bearing wear ...
  4. Dec 9, 2012 at 6:39 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    canton Ga
    06 reg cab sr5
    General lee horn mod, Bilstein 5100's and maxtrac 4 inch lift spindles. omd spring rebuild w/ s10 springs kenwood h/u and cb, warn trans4mer brush guard level 8 tracker wheels and cooper s/t 33's
    Might also be the input shaft pilot bushing
