2.7 dyno charts
Discussion in '4 Cylinder' started by tooter, Jul 9, 2013.
  1. Jul 16, 2016 at 9:34 AM
    #121
    Dean2016
    Dean2016 Active Member
    Dean
    2016 tacoma SR 4x4 5sp
    Also found an exhaust at URD it's an afe, and according to them they dyno tested 7hp and 14pd of torque on it. http://urdusa.com/store/Exhaust-&-H...haust,-2013+-Tacoma-2.7L-I4/product_info.html
    Also @Nskcorona I would personally not recommend switching to electric fans, I've had them on my 4runner and not only did I not notice an ounce of difrences in power or acleration or throttle response the fans would often stay on after I had parked because they read they radiator was hot, so they would just keep going and drain my battery. Apparently there is a way round that, but you have to wire it into your ignition. All in all It was pain in my ass for nothing.
  2. Jul 16, 2016 at 10:01 AM
    #122
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Spal electric fans, with a wiring harness from Ron Davis Radiators, would definitely cool the radiator more than stock. Relay wired in, and not wired into the ignition. Key off and they are off. They work extremely well, even in summer months. Mounting them would be the trick though.
  3. Jul 16, 2016 at 11:00 AM
    #123
    Nskcorona
    Nskcorona Member
    2014 Tacoma 2.7 DCSB prerunner
    Lce long tube headers Urd Mk3 supercharger
    @Dean2016 yea that's the same response I keep getting.. But the LCE website says that's the best bang for your buck because it takes away the hp used to turn the oem fan compared to the electric.. And yea I seen the afe exhaust and I'm still deciding on which one.. Because I want it to pair nicely with my LCE headers.. Plus I kinda don't want to sound like a civic lol
  4. Jul 17, 2016 at 5:02 PM
    #124
    SnowB0und
    SnowB0und Well-Known Member
    4cyl 4x4
    I was just up there with mine, fully loaded with Kayak on top. Drove just fine, even drove up Old Priests Grade road in 2nd with no problems.
  5. Jul 21, 2016 at 7:58 PM
    #125
    jjustjjosh137
    jjustjjosh137 Well-Known Member
    Josh
    Pensacola
    2010 taco 5speed 2.7l 4wd
    None yet
    @tooter Are you doing anymore manifold spacers? i would definitely be interested in one
  6. Mar 29, 2019 at 10:13 AM
    #126
    The_Sahara_Man_FJ80
    The_Sahara_Man_FJ80 Never Settled
    Ish
    NorCal; Santa Cruz <—> SF <—> Lake Tahoe
    2004 2.7l Tacoma 4WD
    -- OME Dakar Leafs -- ToyTec adjustable shackles —allpro armor— -- Bilstein 5100s all around -- Toytec Coils -- Ebay UCAs w Allpro Uniballs --Toyota bug/wind deflector -- Weld Racing Scorpios -- SnugTop Hi-Liner — BedRug Bedliner --Spyder LED Tails -- Black Horse taillight guards --33"Cooper STT Pros -- 800w Quad row spot/flood LED bar -- Uniden Bearcat CB -- Firestik 5ft antenna -- K&N CAI
    Thanks for this!! Anyone install the LCE or other headers on a 2.7 auto?? It says to relocate oil dipstick for autos... wtf?
  7. Sep 23, 2020 at 5:49 AM
    #127
    Kmier
    Kmier Member
    Ken
    Birmingham, AL
    2011 Tacoma AC 2.7L Auto
    I know this thread is over a year old, but I’m thinking of the LCE header for my 2011 2.7 auto. Is there any truth to the need to relocate the dipstick??
    Also, LCE recommends replacing header studs and nuts with the upgrade. Any tips on removing the old studs without breaking them? Soak them down first for a couple of days with a penetrant?
    Thanks in advance,
    Ken
    davidstacoma likes this.
  8. Sep 23, 2020 at 6:16 AM
    #128
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Which studs do they recommend replacing them with? OEM, or aftermarket?
  9. Sep 23, 2020 at 7:08 AM
    #129
    Kmier
    Kmier Member
    Ken
    Birmingham, AL
    From the LCE site:
    Header Stud Set
    The factory exhaust manifold studs have a shoulder in the center that can interfere with proper header tightening. Our 10mm x 48mm long, heat treated and plated header mounting studs are stronger than stock.
    Kit Includes:
    • (8) Studs
    • (8) Mechanical locking nuts
    NOTE: Torque to 33 Ft. Lbs.
  10. Sep 23, 2020 at 7:12 AM
    #130
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Good. Might need to use a thread chaser, if the threaded holes are too tight.
  11. Jan 28, 2022 at 10:23 AM
    #131
    Shawn989116
    Shawn989116 Member
    Robert
    2018 Tacoma SR5 4x4 2.7L 2TR-FE
    ARB Air lock diffs + 4.88 Ring pinion
    Hey whats up guys, I saw tooter who was making the spacers has disappeared from tacoma world unfortunately. I bought an OEM intake manifold and CMM measured everything to ensure accuracy and made serveral of the spracers 2 inches thick. They offered in a kit in which ive made brackets for this to be a bolt on item, Let me know if anyone's is interest in a kits by private messaging me or just reply back to this post. im glad i can help continue on the tacoma manifold runner.
    Torspd and WTORRES141 like this.
  12. Jan 28, 2022 at 11:33 AM
    #132
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Well done. :thumbsup:
  13. Jan 28, 2022 at 11:34 AM
    #133
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This would be good to be posted here:
    https://www.tacomaworld.com/threads/2tr-fe-performance-thread.636292/page-63
  14. Jan 28, 2022 at 12:13 PM
    #134
    Shawn989116
    Shawn989116 Member
    Robert
    Thanks Torspd!, I posted up in the performance thread!
    Torspd likes this.
