2.7 Engine acting up, need help
Discussion in '1st Gen. Tacomas (1995-2004)' started by yota97, Apr 12, 2012.
  1. Apr 12, 2012 at 12:04 PM
    yota97
    yota97 [OP] Active Member
    97 Tacoma 4cyl 5 speed
    6 inch Fabtech suspension lift 2 inch body lift K&N cool air intake custom headers Mossy Oak upolstry Wheels and Tires
    so my yota has been sitting for about 2 months cuz of front end problems and now i finally got it on the road, she ran mint the first drive and now she will sit and idle for a bit then she starts sputtering could it be the gas is to old? any ideas
  2. Apr 12, 2012 at 6:31 PM
    natemoore2088
    natemoore2088 Well-Known Member
    Nate
    Idaho
    '97 Tacoma 2.7
    2" lift Pre-runner bumper Deck Plate Doug Thorley header Cherry Bomb
    Any codes? Probly gas if there aren't any codes, maybe fuel filter. Put an additive like heat in and see if it fixes it. Make sure you fill the tank when you put any additives in.
  3. Apr 12, 2012 at 9:12 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, 31" tires, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    Does it matter whether its cold or hot?
    Does it run fine when not idling? If so, it could be the TPS.
  4. Apr 13, 2012 at 9:29 AM
    yota97
    itll run fine right at start up then once she gets warm it starts to sputter, i did de grease the engine yesterday too and wasnt until i did that she started acting up
  5. Apr 13, 2012 at 9:32 AM
    gastoverat
    gastoverat Active Member
    Fortson Georgia
    96 Tacoma Lx 4x4
    Probably got something wet.
