2.7 fuel filter?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Quicktime_GT, Jul 24, 2008.
  1. Jul 24, 2008 at 9:07 PM
    Quicktime_GT
    Quicktime_GT [OP] Active Member
    2.5 inch spacers 2 inch blocks rancho shocks
    Planning on changing the fuel filter.. its been over 100k without being changed. I layed under the truck but didn't see it where I would have thought it would be..
    Anyone have any tips or know of a good write up ?
  2. Jul 24, 2008 at 9:09 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    It's under the exhaust manifold. IIRC, you have to unbolt the manifold a little to get the filter out.
  3. Jul 24, 2008 at 9:09 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    actually, if im not mistaken, its kinda under the backside of the intake on that truck. it may be a bitch to get to, but its doable. send a pm to chris4x4 and see if thats exactly where the filter is.......i dont wanna lead you in the wrong direction at all!:)
  4. Jul 25, 2008 at 9:17 AM
    moelkhuntr
    moelkhuntr New Member
    SE MO
    03 4X4 SR5 Reg.Cab 265X75X16
    Done mine a couple days ago. It is really a royal pain. It is under the intake on the drivers side mounted to the block. Took the drivers side front wheel off and that helped some by using a really long extension to losen the bolts that hold the filter to the block. I sloted out the bottom mounting bracket hole to slip it back over the bottom bolt when remounting it and made it easier to put back on. Put the bolt in the block and slipped the bracket over it and then tightened it when I had the top one in. That really helped.
  5. Jul 25, 2008 at 9:29 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    None!
    I did mine on my 98 3RZ and it was a major pain in the ass. Good luck man.
  6. Jul 25, 2008 at 8:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It is under the intake. If you decide to change the filter, give some thought to relocateing it. There are many places it can go, just be sure to have the right parts. That way, it will be a piece of cake in the future. :)
