2.7 is running bad
Discussion in '1st Gen. Tacomas (1995-2004)' started by Nicest96, May 16, 2012.
  1. May 16, 2012 at 8:34 AM
    Nicest96
    Nicest96 [OP] Member
    Bill
    New hampshire
    96 tacoma 4x4 2.7l
    6" fabtech suspention lift, 4.56 gears, bushwacker fender flairs,
    I have a 2.7l and wen it hits about 2500 rpms it seems to fall on its face almost like a cylinder isnt firing or something. Has anyone else had this problem?
  2. May 16, 2012 at 8:38 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2018 T4R & '95 SAS
    SAS, dents, & scratches
    Any check engine lights?
    I would try cleaning the maf and throttle body.
    Welcome to Tacomaworld!
    EDIT: also how many miles? I suppose timing could be off a tooth... but that is over my head :eek:
  3. May 16, 2012 at 11:30 AM
    SpazzyB
    SpazzyB Master of the Prius...
    Ryen
    neuf un six
    '04.5 vw stance machine
    when's the last time you changed your spark plugs? could be fouled and producing a strong spark.
    when it's dark, with the truck running(if it's runningat all) with a squirt bottle(mist setting not stream) spray water around the plug wires(coil packs) and look for an electric afro.
    when's the last time the fuel filter was changed?
  4. May 16, 2012 at 7:02 PM
    dentaco76247
    dentaco76247 Registered Mud Abuser
    Greg
    Justin, TX
    97 Tacoma xtra cab 4x4
    4Runner bucket seats, Upgraded headlights Blistein 5100s Blacked out Grille
    in fuel tank and intake vacuum line. Then drive it like you stole it
  5. May 18, 2012 at 5:56 AM
    Nicest96
    Bill
    New hampshire
    96 tacoma 4x4 2.7l
    Thanks everybody for the welcome. And i tried seafoaming in the vacuum line. It worked for a little but then started do it again
  6. May 18, 2012 at 2:52 PM
    Stew
    Stew Well-Known Member
    Stew
    Greenville, NC
    White 04 Single Cab 2.7 4x4
    2.5in ^, debadged, fog light mod, deck plate, line-x, tool box
    Change your fuel filter.
  7. May 18, 2012 at 3:44 PM
    dentaco76247
    Greg
    Justin, TX
  8. May 18, 2012 at 3:49 PM
    Faryota
    Faryota Well-Known Member
    Mic
    Ridgefield, WA.
    13, 4x4, long bed, Sport, Debad
    6" BDS lift in front, warn winch, AFE cold air intake & exhaust, Body Armor Rear bumper, Tuffy in bed storage box, DZ bed mat, ARB front bumper & Warn winch w/light kit, Husky floor mats, dash mat,
    Welcome!
  9. May 18, 2012 at 4:02 PM
    dentaco76247
    Greg
    Justin, TX
    post pics of your rig when you can
  10. May 25, 2012 at 6:28 AM
    Nicest96
    Bill
    New hampshire
    96 tacoma 4x4 2.7l
    Yesterday i changed te fuel filter and cleaned the entire intake with intake cleaner and break clean and a ton of black gunk came out of it and now it seem to be running mint again. Would it be a good idea to seafoam it again? And i will try to put pictures up once i get access to a computer.
  11. May 25, 2012 at 12:44 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    If you want to foam it again I say wait till your next oil change.
    Seafoam a couple days before you change the oil.
