2.7 Liter oil leak from filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Storm_Trooper_Tacoma, May 24, 2016.
  1. May 24, 2016 at 8:17 PM
    Storm_Trooper_Tacoma [OP] New Member
    Philip
    2.7 L4 Regular Cab SR5 Prerunner
    12" Subwoofer Kenwood head unit Boss armor amp
    So I purchased my truck used. From a guy out in a rural area of my state. And when I changed the oil I had to put my wrench insisde a pipe to get the oil drain plug out.
    About a week after the oil change and filter change ,I noticed oil drips on the pavement of my buddy's driveway. After some investigation we discovered a leak that is directly under the filter.
    The filter is the right size and the oil is the right viscosity. I have tried tightening the filter ect.
    What are some thkngs I can try to fix my truck?
  2. May 24, 2016 at 8:23 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Did you make sure that the old filter didn't leave the gasket in place?
    Are you sure it is the filter that is leaking?
  3. May 24, 2016 at 8:23 PM
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    Are you sure the rubber seal came off with the old filter? If that seal was stuck to the block and you screwed a new filter on, it will leak. That's the first thing I'd check. I've seen it happen many times.
  4. May 24, 2016 at 8:24 PM
    MKW
    Murrells Inlet, SC
    2014 RC 4x4
    LOL...you beat me to it!
  5. May 24, 2016 at 8:26 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    By seconds!
  6. May 25, 2016 at 1:36 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    My advice is NEVER use a wrench to install an oil filter. Lube the gasket, install until gasket contacts the block, add 1/2 to 2/3 turn. Also means next time no wrench is required to remove it.
    nickj604 and Jimmyh like this.
  7. May 25, 2016 at 10:02 PM
    Philip
    I didn't think to check for the old gasket. I know my truck can take two kinds of filters for some strange reason. So I'll go for the one that was on the truck before I changed the oil
