2.7 Oil Overfull
Discussion in '4 Cylinder' started by 2TRunner, Nov 4, 2010.
  1. Nov 23, 2010 at 4:18 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Cold, dense air needs more fuel to maintain the correct mixture. It produces more power than hotter, less dense air. This is the basis for all types of air induction power adders, ie. Turbo, supercharger, ram air, cai. More air and more fuel = more power. Add an intercooler to turbo and supercharger, you get even more power since the air is cooler.
    Are you with me? I can't do the math anymore to prove the point, but it can be done.
  2. Nov 23, 2010 at 4:20 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I always fill with 6 qts. of full synthetic and I still pull 31+ mpg's on the highway.
  3. Nov 24, 2010 at 6:43 PM
    The Shape
    The Shape Well-Known Member
    Forrest City, AR
    '09 Access Cab A/T 4banger
    First few oil changes I used a full 6 quarts, last few I have used 5.5. I think really as long as you use atleast 5 and no more than 6 you are golden. An extra 1/2 quart of oil is not going to make your truck drive any different or effect MPG.
  4. Dec 3, 2010 at 12:40 AM
    2TRunner
    2TRunner [OP] Snoop Dad
    My House Usually
    Hmmm....
    Filled up around 1/2 tank left with some 93 octane. Other half of the tank was 89 octance.
    MPG is doing better.
  5. Dec 3, 2010 at 3:28 AM
    rjreynolds
    rjreynolds Active Member
    2wd 2.7l
    You can do what you want with the dipstick, but make sure that you have a total of 6.1 quarts in there. I am 100% convinced that you are supposed to have that amount with filter. What weight oil are you putting in?
  6. Dec 3, 2010 at 5:08 AM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    So you think Toyota released hundreds of thousands of dipsticks that read wrong.
  7. Dec 3, 2010 at 5:59 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    So you're worried that your mileage went from 22.5 to 21? Maybe something as simple as you floored the gas a few extra times during that tank?
  8. Dec 21, 2010 at 3:24 PM
    Taco.Tim
    Taco.Tim Well-Known Member
    Tim
    Georgia
    2010 Buhlue Access Cab 2WD
    Looking!
    I noticed my 2000 'vette gets worse mileage in the winter and agree it is because of the air/fuel ratio.
    On another note, I talked to the Amoco guys in the late '90s about summer mix versus winter mix gas, and they told me they put more additives in the summer mix to help prevent vapor lock. It also makes the summer mix cost more. All I knew before then was the summer mix (Amoco 93) was consistent in my wife's bracket car, and the winter mix was definitely not. After that we would buy a 55 gallon drum full of summer mix Amoco 93 in August and use it for the rest of the season (usually late October).
    Tim Glover
  9. Jan 1, 2011 at 9:05 AM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    I just toss 5qts in the 03 and call it a day always right near the full maybe a hair below
  10. Jan 1, 2011 at 10:50 AM
    CometKat
    CometKat Well-Known Member
    Carson City NV
    08 Tacoma 4X4 Regular Cab SR5
    Toyota is not a company that likes to admit mistakes
  11. Jan 6, 2011 at 9:35 PM
    nOLd
    nOLd Well-Known Member
    nold
    Dallas
    so 5 quarts or 6 quarts for a 2.7 engine second gen? manual says 6.1 quarts
  12. Jan 6, 2011 at 9:54 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I use 5.5 quarts in my V6 like the manual states. To make the dip stick easier to read I used a small round file and etched marks in a "X' pattern on both sides of the stick.
  13. Jan 7, 2011 at 4:13 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    split the difference and call it 5.5 including the filter.
  14. Jan 11, 2011 at 8:44 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Toyota released hundreds of thousands of pickups with inferior build quality compared to the previous generation, so the dipstick theory is certainly plausible. The jury is still out on the design, whether it's actually better than the first gens.
    With my 2.7, I put 1/2 qt into the filter before installation and 5 qt in the case, then run it and check for leaks. I don't check the level until the next morning because that's the only way to get a good read. If I need to drive it after the change but before checking the level, I don't worry because 5.5qt is certainly plenty and puts it just under the full mark.
  15. Jan 11, 2011 at 12:25 PM
    #35
    91r100gs
    Dan
    Kansas City area
    Last oil change I put 4 oz in the filter to soak the filter and put 5 qts in as usual and it was right on the upper line. Aint blown up yet. The time I put in 5.5 qts it was quite a bit above full. IMO is just isnt that big of a deal.
  16. Jan 24, 2011 at 5:10 PM
    #36
    bjscullysr
    bjscullysr New Member
    08 reg cab 4x4 4cy SR%
    On my first oil change w/ my 2008, 2.7 I put in the 6 qts and dip stick was reading way over full. I drained some out and have been using about 5 qts since then. Good to see that others have noted the same issue.
  17. Jan 24, 2011 at 5:34 PM
    #37
    CometKat
    Carson City NV
  18. Apr 9, 2011 at 2:07 AM
    #38
    2TRunner
    My House Usually
    Sorry 4x4....Got a crow?
    I'm shocked...shocked at how badly the cold weather effects the truck. I love everything about my truck, but this is a bit nutty. Never seen a vehicle react this poorly to cold weather. It's not just a little bit, it KILLS the mileage. I had to switch up to 93 octane to get any kind of mileage out of a tank in the winter.
    And we had a long winter. I was more angry about the cold weather b/c of my trucks MPGS than the actual cold weather. "Just warm the F up so I can get good mileage again"
    Once the weather warmed up...MPGs have started improve.
    Got any ideas on a way to help this situation out?
    Its probably is a bad idea, but I tell ya' I've been wondering if somehow, something could be modified/fabricated that would route some exhaust back up into the air box.
    Somehow tap into the exhaust pipe near the tail end and run it all the up to the air box. If the cold air is not helping anything, then maybe getting some "warm/hot" exhaust into the air box would help???
  19. Apr 9, 2011 at 6:04 AM
    #39
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    What are your MPG's in warm weather vs. cold weather?
  20. Apr 9, 2011 at 6:41 AM
    #40
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    That they are following their documentation but not necessarily what the reality of the situation is?
    Agreed & ditto.......
