2.75 lift ?
Discussion in '5 Lug' started by BforBriAN, Nov 24, 2013.
  1. Nov 24, 2013 at 4:52 PM
    BforBriAN
    BforBriAN [OP] Member
    Brian
    Jacksonville
    hey guys i am getting the 2.75 lift and rear AAL and plan on getting 31/10.5/15 tires on the stock steelies. My question is was there any rubbing or anything with this set up. I've looked through the threads and no answer. Thanks!!
  2. Nov 24, 2013 at 5:06 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    31's on a 2.75" lift? I don't see rubbing being a problem. What are you doing up front for your lift?
  3. Nov 24, 2013 at 5:14 PM
    BforBriAN
    Brian
    Jacksonville
  4. Nov 24, 2013 at 5:19 PM
    teneighty
    Already ordered?
  5. Nov 24, 2013 at 5:20 PM
    BforBriAN
    Brian
    Jacksonville
    nope not yet haha why?
  6. Nov 24, 2013 at 5:21 PM
    teneighty
    You won't rub with 2.75". I run a 32" tire with no issues and I'm at 3".
  7. Nov 24, 2013 at 5:22 PM
    teneighty
    Pick yourself up a set of Bilstein 5100's and set them at 2.5" for the front.
    That kit is overpriced for what you get.
  8. Nov 24, 2013 at 5:25 PM
    teneighty
    Front height adjustable 5100's ($170) Rear AAL ($75)
  9. Nov 24, 2013 at 5:30 PM
    BforBriAN
    Brian
    Jacksonville
    will those work on a 5 lug? haven't seen many on here with those i don't think
  10. Nov 24, 2013 at 5:32 PM
    BforBriAN
    Brian
    Jacksonville
    actually just found the thread...they won't work on 5 lugs thanks though
  11. Nov 24, 2013 at 5:38 PM
    teneighty
    Ahhh your a 5 lugger haha
    Give yourself some good research time before you purchase. Lots of info on here to steer you one way or another. I looked to see what you had for a truck but only saw it was an 09'
  12. Nov 24, 2013 at 5:43 PM
    BforBriAN
    Brian
    Jacksonville
    haha yeah man thanks though sweet truck btw
  13. Jan 7, 2014 at 10:16 PM
    .MarkyMark.
    .MarkyMark. Jesus follower
    Mark
    Oceanside, CA
    2007 Regular Cab, 5-Lug
    ReadyLift SST w/AAL, Rancho RS5000 shocks, Volant CAI, 1.25" Hub-Centric Spacers, FJ Cruiser Seats, Tint, Stereo, more to come
    I just installed the ReadyLift SST w/AAL (2.75"f, 1.75"r) kit on my 5 lug and plan on throwing 31's on it Saturday. I currently run 235/75/15 and which basically calculates out to 9.25" wide. The rear tires at 31x10.5 will be just fine, it's the front that will rub against the stock sway bar at full lock. Instead of buying wheels (I like the stock look), I'm gonna throw on some hub-centric wheel spacers at 1.25". I like the clearance the 235 has from the sway bar, so if I'm increasing the width by 1.25" I need to space the wheel at least .75" but I want to have a slightly wider stance in the front. Do keep in mind that the rear shocks will need to be replaced for ones with longer length and after extensive research I chose the Rancho rs5000's because they are about 2" longer than the bilstein 4600hd's (which are the only bilstein's that will properly fit a stock 5 lug). Good Luck.
  14. Jan 8, 2014 at 10:21 PM
    dustleet
    dustleet Well-Known Member
    Sok
    94115/94087
    '13 Tacoma Reg 4x2
    pm'd
  15. Jan 19, 2014 at 12:19 PM
    Card1
    Card1 Well-Known Member
    Georgia!
    96 taquito
    Doestch Spindles
    Why didn't you just get eibach lift coils?
  16. Jan 19, 2014 at 12:20 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Southern New Mexico
    2018 Tacoma TRD Off Road 4x4
    Again, if you're talking about the Eibach coils from Toytec you can NOT run those on a 5-lug. People have told you this already. So stop recommending this please.
  17. Jan 19, 2014 at 12:32 PM
    Card1
    Georgia!
    96 taquito
    Doestch Spindles
    It's gonna work! All depends on how bad you want them
  18. Jan 19, 2014 at 12:34 PM
    PcBuilder14
    Brent
    Southern New Mexico
    They are way too stiff and will max out your lower and upper ball joints leaving you absolutely no travel.
    Unless you do some custom fab work on your coil buckets and everything. The Eibach lift coils will NOT fit a 5-lug.
    Toytecs website even states this:
    "NOTE: Toytec Lifts Suspension parts do not fit 5 wheel lug Tacoma’s.
    Please check your application before ordering."
  19. Jan 19, 2014 at 4:11 PM
    Card1
    Georgia!
    96 taquito
    Doestch Spindles
    Not tryina be a d' but do you know the requirements? i want a mid travel setup for my truck. i feel like i could do the shock hoop setup to bring the mounting up a little higher and BPE to make the bottom fit in place. unless i get some ctrl arms.
  20. Jan 19, 2014 at 10:46 PM
    PcBuilder14
    Brent
    Southern New Mexico
    No clue. I'm sure you could fab something up though.
