2.7L cold start rattle?
Discussion in '4 Cylinder' started by kim414may, Oct 21, 2012.
  1. Oct 21, 2012 at 8:33 AM
    kim414may
    kim414may [OP] Member
    04 tacoma prerunner
    Hi. I have a 2004 Tacoma Prerunner 2.7 L 3RZ engine rattle or clatter that happens first thing in the morning. This rattle gets longer with colder mornings. It started maybe last year and now I am reminded of it.
    The truck has 150k and oil level is at full. I have been running synthetic valvoline and mobil 1 since day 1 with the truck.
    It runs perfectly fine. Just this weird unusual rattle that goes away once it warms up. I have seen other and older posts relating to a possible piston slap? Others have also said this is normal for this engine. And my dad listened to it and said it is in need of a valve job.
    Any suggestions or ideas? Thanks.
    http://www.youtube.com/watch?v=cQpH0GIcTgg
  2. Oct 21, 2012 at 1:17 PM
    frog13
    frog13 Well-Known Member
    Not trying to be a clown,but you say your running synthetic oil.......what grade though?.....0w-20,5w-30 or what?. I am not a mechanic,but some vehicles are quite particular about oil grades.
  3. Oct 22, 2012 at 9:41 AM
    kim414may
    04 tacoma prerunner
    5w30. I live in San Diego relatively mild weather in my opinion.
  4. Oct 22, 2012 at 1:25 PM
    BamaToy1997
    Bill
    Navarre, FL
    That noise is DEFINITELY not normal. It is hard to tell with the other background engine noises on a video though.
    One way to check location is with a mechanical stethescope. They are relatively inexpensive and are worth their weight in gold when trying to track down noises.
  5. Oct 23, 2012 at 5:46 PM
    LDurchy
    LDurchy Well-Known Member
    Cedar Falls, Iowa
    Something you can try is to turn on the air cond. during this sound and see if the rattle stops. Thinking of the electric clutch rattling on the air cond. compressor. If the rattle stops immediately, the electric clutch is your culprit. If the rattle continues then you can omit the air cond. clutch as a culpret.
  6. Oct 23, 2012 at 6:32 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Def not the particular Toyota tick, would get this checked out. Mine makes a low tapping sound on cold mornings but goes away as soon as its warmed up. Yours sounds like a rod knocking, but I doubt that's what it is. If it was a rod knock it would be doing it all the time regardless of engine temp.
  7. Oct 23, 2012 at 7:47 PM
    AlaskanTaco
    AlaskanTaco Well-Known Member
    Anchorage Alaska
    09 sr5 acc cab tacoma
    Sounds like some good old piston slap to me. Typical on GM's. Normal for most vehicles.
  8. Oct 23, 2012 at 10:26 PM
    808Bradah
    808Bradah Well-Known Member
    Hawaii
    2012 Super White SR5 4cyl
    mines has a similar sound, I have a 2012 with 5k miles and I always have a rattle during cold starts cept mines seems to be coming from the muffler area. took it to the dealership and they had no idea what the problem is so they put some insulation or something on the spare tire chain to see if that helps from eliminating the rattle and it still rattles on cold starts in the morning.
  9. Oct 24, 2012 at 1:54 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    You've had it since day one -- how long has it been making this noise? Has it always made this noise but it's just getting louder now so you are becoming concerned? Anyway I agree it's probably piston slap... nothing to worry about, just don't rev the motor too high until it gets mostly warmed up. High revs are not good for cold engines.
  10. Oct 24, 2012 at 2:59 PM
    paid4c4
    paid4c4 Well-Known Member
    Northern KY
    2015 4X4 TDR Sport, Auto Extended Cab
    You definitely have something going on however it sounds too much like "tin" instead of a solid rod knock or piston slap. Try to rule out the AC clutch and exhaust pipe vibration. If you are using 05/30 oil try 00/30 see if that helps. You're not in really cold weather so perhaps something as simple as oil might help. Please let us know how this turns out, I'm interested as I have a 2.7L also although I'm just getting broke in at 44K miles.
    Bill
  11. Oct 24, 2012 at 11:22 PM
    kim414may
    04 tacoma prerunner
    Thank all of you guys for your suggestions.
    But yes I have had this truck since day one and it never made this sound. I heard it first around last winter maybe January-February but did not think much of it since it goes away. And as the winter turned to spring then summer, the cold mornings were not as cold so that rattling noise does not happen. But now that it is getting colder again and the truck's mileage is getting higher, I am getting concerned. To top that off was my discovery of TacomaWorld so here I am asking for input.
    It gets frustrating though. I'm not mechanic savy but I have some experience doing simple repairs which I learned during my roommate situation. All I know is that if it's a warm or mild morning, this rattling doesn't happen. If it's a damn cold morning where you feel like you fingers are going to fall off, the rattling happens. I also live in a condo complex with no garage so extensive mechanical work is out of the question otherwise I can get fined ($100-200) if caught.
    I will plan on leaving this car overnight on a cold night at the mechanics (a close relationship since this mechanic's parents are good friends with my boss's parents and I have a good relationship with my boss) and bring the suggestions listed here to see if that helps to point him in the right direction. Because once the truck becomes warm, the rattling stops and we would have to wait again for another cold morning.
    I am going to update it I find out anything. This prerunner has been a gem taking my family and I up and down the states so I definitely plan on getting it taken care of ASAP. Just waiting for the truck's next service and saving up some cash.
  12. Nov 2, 2012 at 11:34 PM
    scriber007
    scriber007 Well-Known Member
    This is the same exact sound my 04 3rz doublecab makes. It's very frustrating trying to pinpoint where the noise is coming from. My truck has 127k miles. Although my happens when I put it in reverse and drive. I have to warm it up too for at least 1 min. Let me know after your mechanic finds out the culprit.
  13. Nov 17, 2012 at 3:10 PM
    Paulie
    Paulie Well-Known Member
    Paulie
    USA
    Tacoma
    Same deal here, if it's not a major mech. thing, try Amsoil 0w-30. Mobile 1 is a group III and not really synthetic. Amsoil is a group IV and far superior to Exxon etc.
  14. Nov 17, 2012 at 4:14 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    What oil filter are you using. Make sure the filter you are using has a silicon anti-drainback valve. If unsure try a purolator pure one in the correct size.
  15. Nov 17, 2012 at 5:20 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Amsoil uses Mobil-1 base stocks.
    Their additive package is different, but the base oils are identical.
    Pretty much all automotive synthetics have been Group-3 blends ever since Mobil lost the Castrol lawsuit. The only fully group-4 synthetics still offered by Mobil or Amsoil are their motorcycle blends.
  16. Nov 17, 2012 at 5:22 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    The drainback valve doesn't matter on the inverted filter on the 2nd Gen 2.7... not sure the orientation of the 1st Gen 2.7.
  17. Nov 17, 2012 at 7:22 PM
    91r100gs
    Dan
    Kansas City area
    He does not have a 2nd gen. his is a 2004 and may be different. Never seen a 1st gen
  18. Nov 20, 2012 at 3:17 PM
    BamaToy1997
    Bill
    Navarre, FL
    The 2.7 1st gen is a inlet/outlet up filter, and does not require any type of drain-back prevention.
  19. Nov 28, 2012 at 7:45 AM
    cowboy50
    cowboy50 Well-Known Member
    Dexter,MO
    05 Tundra 4x4
    Wish I would of seen this sooner mine does the same thing 01-2.7 200K on it now. But mine even did it during the spring when leaving work it wouldn't rattle on start up but on acceleration from parking spot it would. I could let up on it and it would stop, push gas down again and it would knock. But this would stop within 2 city blocks.
  20. Nov 18, 2013 at 1:22 PM
    Axelnutz
    Axelnutz New Member
    Any word on what the problem was? I have an 03 tacoma 2.7L with the same exact noise on cold days.
