2.7L cold start rattle?
Discussion in '4 Cylinder' started by kim414may, Oct 21, 2012.
  1. Nov 18, 2013 at 1:29 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    does it have a timing CHAIN or belt?-1st thought when you reported mileage-timing CHAIN RATTLE.
    has it been replaced?
  2. Nov 18, 2013 at 8:08 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    2.7 has a chain.
  3. Nov 19, 2013 at 5:57 AM
    cowboy50
    cowboy50 Well-Known Member
    Dexter,MO
    05 Tundra 4x4
    From everything that has been said I would have to say piston slap. Till someone tears one down and checks it with a fine tooth comb. That seems to be the most (logical) answer Captain. I just don't throw the coals to it first thing in the morning when it is cold. Mine set outside for 3 years and since we built a garage and I keep it in there the knocking has seemed to let up somewhat. 215K don't use any oil and I use 5w-30 synblend. Just like a Timex, takes a licking and keeps on ticking.
  4. Nov 19, 2013 at 6:38 AM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    ^^^Sound advice. Pushed my 95 up to 250k, and in the winter she knocked really hard just like the video. I don't recall when it started, but I think it was closer to 200k.
    What I did to keep the engine strong:
    -synth 5w in the winter and 10w in the summer
    -relocated the oil filter (added volume, allowed for a bigger filter, no more messy oil changes)
    -run high octane fuel when the nasty cold really sets in
    -drygas every two or three fill ups during the winter
    -conduct ALL regular maintenance at recommended or shortened intervals
    -when I started it in the morning I just let that truck sit there and idle, the colder it was the longer she warmed up, I almost never had to brush snow off the truck as it had all melted
    -monitor and top of all fluids during oil changes
    OP, it was mentioned above and bears repeating: Don't jump in the truck when its cold as hell and start romping on the gas or driving off while its knocking. You will greatly accelerate wear and tear, and then one day she'll quit in a very unladylike fashion.
    If you would like to do a little added "preventative" maintenance check to see when the oil pump was replaced last, if at all. Check the oil pressure. If you're worried about gunk built up in the motor do a search in the forums for "seafoam". Dunno how good that stuff is, I never bothered to use it.
    I'm assuming you're on an air base. Go find the automotive hobby shop. It's either free or dirt cheap, and they have every tool you'll ever need as well as a clean and dry place to work.
  5. Dec 28, 2013 at 10:27 PM
    scriber007
    scriber007 Well-Known Member
    Okay I use to get the rattle before, but it went away after I switched to a wix oil filter.
  6. Jan 20, 2014 at 4:28 PM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    My 09" Does this anytime it's under 32ºF. It started two years ago. And I only have 42,000k on the truck.
    I was going to explore switching oil brands.
  7. Jan 21, 2014 at 5:24 AM
    cowboy50
    Dexter,MO
    05 Tundra 4x4
    I was using 5w30 like they say to use. Switched to high mileage syn-blend 5w30 and it still rattles but not on start up. It does it when it is put under a load, but only if I don't give it at least a 5 minute warm up. We have been in the single digits this winter, haven't had that in a long time.
  8. Jan 21, 2014 at 5:41 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    "single digits" In NJ 2. Welcome 2 Global Warming:D
  9. Jan 21, 2014 at 6:14 AM
    sgoodwin1
    sgoodwin1 New Member
    03 Tacoma Prerunner 2.7L
    Has this been fixed? I keep reading "piston slap" but has anyone had this actually confirmed? I too have the same noise only when cold but it doesnt do it every time. If in fact its "piston slap" wouldnt it do it every single time its cold? The fact that it does away within seconds after starting and the oil pressure builds has me leaning more towards timing chain,guides and tensioner. I know if your tensioner loses prime that chain will slap the timing cover and make a similar sound. Has anyone had their motor taken apart and this fixed?
  10. Jan 21, 2014 at 12:25 PM
    tacosoup89
    tacosoup89 Active Member
    Carrollton, Ga
    2003 2.7L PreRunner
    Seems to be a common problem with the 2.7. My truck does the same thing same exact noise on a cold morning and Ive got 130k. Never replaced the chain or guides but people have told me its a good idea. Got a price quote for a timing chain and guide replacement and the mechanic I spoke with said it would be about a $1200 job at about 14 hours labor. Not saying that's what the knock is in fact I would much rather it be piston slap and wish somebody could confirm that.
  11. Jan 21, 2014 at 3:51 PM
    kim414may
    kim414may [OP] Member
    04 tacoma prerunner
    My truck as of today has roughly 165k. I did not look into taking it apart only because the coldest of the coldest season in San Diego is only about 1-2months when the rattle happens. It goes away in less than 10 secs....drives normal. I feel it is not worth the money and effort to dig into it unless I really knew for sure what I am looking for. Just my personal opinion.
  12. Jan 21, 2014 at 3:53 PM
    kim414may
    04 tacoma prerunner
    However, I was hopeful someone out there had the same problem with the resources of having looked into it so that way, I would know exactly what it was to be fixed before getting it taken apart.
  13. Jan 21, 2014 at 5:25 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Ever since my truck was new, if left sitting in temps of 20F or so, if I don't let the oil circulate for about a minute, I will get the start up rattle, and it lasts, you guessed it, about a minute.
    I am more inclined to think that this noise might be valvetrain noise. Lots of valves and lifters, and such, can make quite a clatter. Today when I left work it was 30F and I did not let it idle for a bit. In the first 30 seconds of easy driving, you could tell it was on the verge of making noise if I gave it much throttle.
    Me thinks this is just the nature of the beast.
  14. Jan 21, 2014 at 5:36 PM
    CelsisTaco
    CelsisTaco Well-Known Member
    Anthony
    Des Monies, IA
    2011 DCSB
    2 inch lift. LED fog lights (Cali fab) Alpine head unit. Kicker door speakers. Skar subwoofer.
    Almost sounds like something is loose?
    I've never had that on my truck..
  15. Jan 21, 2014 at 7:31 PM
    #35
    Rich91710
    Rich
    Los Angeles
    08 Base
    My '03 Tundra 4.7 sounded like a Powerstroke first start when it was below 50.
  16. Jan 22, 2014 at 5:07 AM
    #36
    cowboy50
    Dexter,MO
    05 Tundra 4x4
    That seems pretty pricey. But if Toyota was doing it their labor is higher than a cats back. I too was hoping someone would have a 2.7 torn down by now and would be able to give some insight as to what the chitty, chitty, bang, bang was. I did go to my local dealer and asked them what long term maintenance requirements were, he told me there wasn't any, as far as timing chain, valve adjustment and such. 216K drive it every day and hope for the best.
  17. Jan 22, 2014 at 2:26 PM
    #37
    tacosoup89
    Carrollton, Ga
    2003 2.7L PreRunner
    Don't know if anybody can tell me for sure but Ive been told that its not the timing chain that wears on these engines its the cheap ass plastic chain guides that give people problems. Im still driving the hell out of my truck at 130k with engine knock and all but Ive been warned time and time again that the chain guides on these trucks do need replacing. Can anybody shine some light on that and tell me if its truth or myth??
  18. Jan 22, 2014 at 8:04 PM
    #38
    Rich91710
    Rich
    Los Angeles
    08 Base
    It can be both.
    If the engine is take care of with regular oil changes, it will go 300k before there's a problem with the chain and guides.
    If the oil is not taken care of, then you get both worn guides and chain stretch. It's not actually "stretch" so much as it is an apparent lengthening of the chain caused by wear at the pivots.
    And while that will be noisy, it will be constant... not go away when the engine warms up, and it is more of a steady clatter than it is the rhythmic knock of piston slap (or a bad bearing).
  19. Jan 22, 2014 at 8:44 PM
    #39
    n0rth
    n0rth Well-Known Member
    J.W.
    New Mexico
    2019 Tundra Platinum
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
    My truck has start up noise as well, its only in cold weather (below freezing). It does not happen if I plug it in (freeze plug and oil pan heater). It seems to be more noticeable since I switched to a Toyota filter previously I had always used Napa or Fram filters.
  20. Jan 22, 2014 at 8:54 PM
    #40
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    i've noticed this banging also but it's not this pronounced. This is the first time I've heard it and i'm leaning towards it's been so cold here lately. I've run Toyota oil and oil filter since I got the truck. I'm at 152K miles also.
    I bet it's the damn monkey that lived in the trunk.
