2.7l Dyno results
Discussion in '4 Cylinder' started by RichXKU, Oct 25, 2009.
  1. Oct 25, 2009 at 4:03 PM
    RichXKU
    RichXKU [OP] Active Member
    Rich
    Berks, PA
    '06 reg. cab 4x4 2.7 5MT
    K&N (Previous owner), DIY OEM Cruise, DIY OEM Int. Wipers
    The local car guys had a dyno day, and since its not an AWD dyno, the STi was out :p, so I brought the Taco. It's stock aside from a K&N filter from the previous owner.
    I can't complain. :)
  2. Oct 25, 2009 at 4:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW! Not bad! :)
  3. Oct 25, 2009 at 4:06 PM
    RichXKU
    Rich
    Berks, PA
    Thanks! I've been lurking since Sept...
  4. Oct 25, 2009 at 4:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well congrates on your 1st and second posts. :)
  5. Oct 25, 2009 at 4:09 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Welcome to TW.
  6. Oct 25, 2009 at 4:22 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Good first post& weolcome To TW.
    Wow, torque looks unusable with that slow rising slope to 4500 r.pm. , don't think I've hit 4500 rpm yet.
    If you look closly between the red/blue lines I can see the words "supercharge me".
  7. Oct 25, 2009 at 5:06 PM
    RichXKU
    Rich
    Berks, PA
    Torque is the flatter set of lines, I had them start the second (red) pull lower, which shows ~130 lb/ft at 1400 RPM.
    I rarely take it over 2500, kinda makes me wish they had the D-4D engine available here.
  8. Oct 25, 2009 at 5:19 PM
    Tacoyota
    08 4wd
    Gotcha, the h.p. is the sloping one.
  9. Oct 25, 2009 at 5:33 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Now I wanna dyno my 4.0L.:burnrubber:
  10. Oct 25, 2009 at 6:22 PM
    Tacoyota
    08 4wd
    I'm curious of what mine would Dyno at, the 2nd filter is pulled, I'm running synthetics, and the fender thing is out going to the air box.
  11. Oct 25, 2009 at 9:05 PM
    SSrUs
    SSrUs Member
    Damascus, Oregon USA
    '09 4x4 SR5 Access Cab 2.7L M5
    3" Lift, Nasta Step Bars
    Cool....looks like about 167 hp at the flywheel. Not bad at all! How many miles on your truck?
  12. Oct 25, 2009 at 10:08 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Sweet. I would like to get my Tacoma dyno.
  13. Oct 25, 2009 at 10:24 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Anyone got a link that will teach me how to read a Dyno chart?
  14. Oct 25, 2009 at 10:25 PM
    df4iguy
    df4iguy Well-Known Member
    Dan
    Chicago
    I think i might throw my 4.0l on the dyno this week
  15. Oct 25, 2009 at 10:59 PM
    crawl
    crawl Well-Known Member
    Greg
    Valencia, CA
    2010 reg cab 4x4 sr5
    nice... dyno chart for your first post :headbang:
    that torque curve is pretty impressive for a stock motor. and it stays strong all the way up the power band. I've been pushing my motor with hard pulls into the upper power band and it has felt nice and strong. your graph shows me proof that our 2.7l motors make power at the higher rpms. thanks for the post.
  16. Oct 25, 2009 at 11:04 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    4 cyl power!
  17. Oct 25, 2009 at 11:06 PM
    crawl
    Greg
    Valencia, CA
    that dip at 3500 is exactly what I felt with my stock intake before I started messing with it.
  18. Oct 28, 2009 at 5:38 PM
    Jeff3004x4
    Jeff3004x4 Well-Known Member
    Jeff
    East Killingly CT
    Timberland Mica
    Stock for now
    I am very impressed with your results I'm currently working on buying a 2010 Tacoma 4cly 4x4 and you just proved my point. The Tacoma with a 4cyl puts more power to the ground then my current truck, a Dakota 3.9 V6. I test drove a Tacoma a few days ago and remember thinking "this truck has more A$$ than my Dakota". However I didn't get to beat on it because I was with a salesman. My Dakota is supposed to put out 175 hp at the flywheel and 125 at the wheels which I think is an overstatement.
  19. Oct 28, 2009 at 6:04 PM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    I've had both,and compared to my 98 v6 manual I think it's pretty compareable. Neither had a lot out of the hole but the Taco has much better top end!
  20. Oct 30, 2009 at 5:20 AM
    Jeff3004x4
    Jeff
    East Killingly CT
    Timberland Mica
    Stock for now
    It is also impressive to compare how much power is lost through the drive line. Dodge looses 50 ish HP Toyota 20 ish. Thats impressive to me.
