2.7L headers, what will it do for me?
Discussion in '4 Cylinder' started by norcal4banger, May 2, 2011.
  1. Aug 27, 2013 at 9:38 AM
    #41
    dillonk1602
    dillonk1602 Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
    what do u guy think about the dt headers for 2.7 2007 taco
  2. Aug 27, 2013 at 5:36 PM
    #42
    ramirezsergio63
    ramirezsergio63 Well-Known Member
    Sergio
    Mecca california
    2012 Tacoma Prerunner SR5 2.7
  3. Aug 28, 2013 at 9:57 AM
    #43
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    Are DT headers worth it I their like $405
  4. Aug 28, 2013 at 12:48 PM
    #44
    ramirezsergio63
    Sergio
    Mecca california
    Get the Lce, at least theres proof that shows some gains
  5. Aug 7, 2014 at 8:38 PM
    #45
    alumaman
    alumaman Well-Known Member
    Yukon
    95 Tacoma
    Header, cold air intake 2" body lift
    I just bought a 95 with a header, cai and dual electric fan. I'm getting 25 mpg and there's no shortage of giddy up and it sounds good. I'm looking at buying another in a bit better shape and I would put these exact things on if I get another one.
  6. Aug 7, 2014 at 10:50 PM
    #46
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I ran an LCE header on my '96 2.4 for a decade...
    and it was the best mod I ever did. The little truck ran great. :)
  7. Sep 13, 2015 at 12:59 PM
    #47
    ddowker
    ddowker New Member
    Has anyone removed the intake silencer box on an 2007 2.7ltr tacoma and if so how?
  8. Jul 7, 2016 at 1:21 PM
    #48
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Just had the local perf muffler shop install my Doug Thorley TRI Y on my 2002 3RZ 4cylinder and I'm impressed with the perf gains and nice exh note
    With the 4 cylinder already running a supercharger and CAI this header install woke it up even more
  9. Jul 21, 2016 at 8:12 PM
    #49
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    You're right. The 2.7 needs to be revved if you want more power. It's still no rocket by any means but I've noticed that once you get above 3000 rpm it does wake up and above 4000 there is even more. Mine very rarely sees past 3000 rpm though. I'm not going to hit the 300,000 mile club taking it past 3000 on a regular basis.
    ocalawill likes this.
  10. Jul 10, 2018 at 9:20 AM
    #50
    Don Vergas
    Don Vergas Well-Known Member
    Adrian
    NorCal
    06 Tacoma DBLCB Trd Offroad
    If i were to install headers but kept the catback stock, would i lose the supposed gains from the headers?
  11. Jul 10, 2018 at 9:56 AM
    #51
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Just install a free flowing muffler and you'll be good
  12. Nov 5, 2019 at 11:23 AM
    #52
    weeksz
    weeksz Well-Known Member
    Adam
    Traverse City, MI
    2017 DCLB Limited
    Stickers mostly
    Is it typical to throw codes while running an aftermarket header? I told myself that days of modifying my DD to throw CELs were over.
    TRVLR500 likes this.
  13. Nov 5, 2019 at 1:55 PM
    #53
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    I have the DTH and I love it really helps out when you are going up hill, It took me about 2 hours for install. I've had no problems it been on the truck for about 5 years now. plus you can pass smog with it installed.
  14. Nov 5, 2019 at 2:32 PM
    #54
    trustyrusty436
    trustyrusty436 Well-Known Member
    2018 Tacoma, auto, 2.7, RWD Access cab, long bed, Utility model
    LCE exhaust header, AF Dymanics CAI, MagnaFlow cat back
    My 2018 does not throw any codes, if I drive it easy it gets over 25 mpg, hold gears better on hills. It feels more like a good in line 6 cyl. than a 4cyl. I installed a Pedal Commander, because it was so slugish before the header, now I hardly ever use it! The truck runs probably close to 4400lbs with me and a full tank of gas and has plenty of giddy up. There is no way I would go back to stock!
  15. Nov 5, 2019 at 7:08 PM
    #55
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    Ive got the lce header on my 2007 2.7l. Installed it myself and had no codes 50k miles later no codes. Like what was already said somthing probably installed wrong or maybe a vacuum hose cane off? I never even threw a code when i had my crappy "cold" air intake installed.
  16. Nov 6, 2019 at 4:05 AM
    #56
    KevinC
    KevinC Well-Known Member
    Kevin
    2017 SR5 Quicksand Tacoma
    Guys is this true? I’m always revving my 2.7 in etc mode above 3000, will this hurt the longevity of this engine? I thought they were bulletproof?
  17. Nov 6, 2019 at 4:34 AM
    #57
    DisneyFan91
    DisneyFan91 Well-Known Member
    Fla., Us
    2018 SR 2.7 DCSB
    What I’ve heard is that while higher RPMs do technically cause some more wear, it’s a surprisingly minimal effect on its own. Simply because the oil does its job when that’s all the engine has to deal with. The thing that really makes a difference is when you have a combination of high load and high RPM, e.g. towing, frequent WOT, etc. The guy was talking about the resistance causing lateral forces in the cylinders. Seemed to make sense to me.
  18. Nov 6, 2019 at 8:03 AM
    #58
    KevinC
    Kevin
    I'm a total newb so I'm learning as I go. I was under the impression that this motor could take on pedal to the metal usage and still last 300k miles. I guess I should stop driving like a dick.
  19. Nov 6, 2019 at 10:26 AM
    #59
    jmarquez808
    Jess
    Hawaii
    No engine is bullet proof, if you constantly pound it and make it work hard youll cause more wear which ultinately shortens the life of the engine. But imo if you drive it hard change oil more often keep up with your maintenance most definately. Ive driven this truck like hell and am the first owner. Just about to hit 150k and shes still going lol. We will see. Im running this till it dies and then maybe swap another used engine in if i can find one because they dont make my regular cab anymore
    KevinC[QUOTED] likes this.
  20. Nov 19, 2019 at 10:57 AM
    #60
    trustyrusty436
    Put one on your truck and let us know! I have an LCE header on my 2018, but from what I've read about the DT headers, their just as good.
