2.7L Intake
Discussion in 'Performance and Tuning' started by 05RedTaco, Oct 18, 2010.
  1. Oct 18, 2010 at 12:24 PM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I want to attempt a DIY intake for my 2.7L 2nd gen Taco. I have already removed the huge resonator which rests inside the fender well.
    Since the stock intake is already cold air intake, I am planning on keeping the stock airbox and replacing the stock paper filter with aFe Pro Dry filter. The outlet of the stock airbox is a tad over 3". 3" is what the diameter of the after market intake is. I haven't measured the throttle body inlet, but I believe the inlet is 2.75".
    So I am thinking of getting 3" aluminum pipe and few angled couplers. 3" coupler from airbox to the aluminum pipe and 3" to 2.75" coupler from aluminum pipe to throttle body.
    Now the difficult thing will be figuring out the angles for the couplers and thats pretty much it. Then getting barb for the valve cover breather & fuel rail breather & drilling and tapping the aluminum pipe. Later on welding the barbs into the intake to prevent possible air leaks after the MAS sensor.
    If I am not mistaken this setup should yield the same amount of gains as aftermarket intake.
    It will actually be BETTER than aftermarket intake, since it will be a true CAI. Also snorkel is possible with this setup.
    Benefits of this setup should be;
    - larger diameter piping from airbox to throttle body
    - shorter distance for the air to travel achieved by removing the 2nd resonator located above the valve cover.
    - less resistance achieved by removing the harmonica coupler between the airbox and pipe with resonator
    This whole setup shouldn't cost more than $100-$120 including aFe filter and should yield the same gains as aftermarket intake.
    Your thoughts?
  2. Oct 18, 2010 at 12:29 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Interesting, can't wait to see how it turns out.
  3. Oct 18, 2010 at 12:29 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
  4. Oct 18, 2010 at 12:31 PM
    05RedTaco
    Tony
    Scottsdale
  5. Oct 18, 2010 at 12:43 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    LINK
  6. Oct 18, 2010 at 12:44 PM
    afd23a
    The Dynamo of Dixie
    Crap.....can't seemed to get the link to work. Let me see if I can fix it :eek:
    Okay the link below worked for me
    new link
  7. Oct 18, 2010 at 12:48 PM
    afd23a
    The Dynamo of Dixie
    Thanks man
  8. Oct 18, 2010 at 12:54 PM
    05RedTaco
    Tony
    Scottsdale
    Yeah I have seen that before. His intake consists of three couplers, I believe it is possible to get away with using just two couplers.
    As well as he used left over parts from intake for another car, I will try to use universal parts and provide list of parts as well as detailed HOW-TO.
    Lastly his intake was most likely more expensive, because it is an AEM intake for Prelude which is at least $200 or more new. I am planning to spend less than $60 in universal parts.
  9. Oct 18, 2010 at 1:16 PM
    afd23a
    The Dynamo of Dixie
    It just seemed like the gains he experienced were mainly at WOT. It didn't sound like it improved anything at lower RPMs, maybe actually decreased performance there. I'm no expert on intakes so maybe you'll have different results.
  10. Oct 18, 2010 at 3:05 PM
    05RedTaco
    Tony
    Scottsdale
    After market intake is; less restrictive filter, larger diameter & more straight forward piping, allowing more air into the engine, when the engine needs it.
    The engine only needs more air than the stock intake can provide in higher rpms and at WOT and that's where will you see gains.
    If you expect the aftermarket intake to give you gains everywhere in the rpm range and at every throttle position, you are in for a disappointment...
  11. Oct 22, 2010 at 8:07 AM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    what does WOT mean? I've been pondering on just using a universal MAF sensor with a AFE filter on it, hopefully that won't kill the performance... ?
  12. Oct 22, 2010 at 10:30 AM
    numbah57
    kahai
    Maui, Hawaii
    WOT = wide open throttle
  13. Oct 24, 2010 at 1:11 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    This is so so very true!
    So my thinking on the subject: the amount of time our trucks spend at high rpm's is nothing (well at least me) so why on earth would I be trying to gain performance of my top end? The thing you want to work on is the powerband you actually drive your truck in. I am trying to find a stock intake system (I would use mine but then id have no intake lol) and I want to see how it would do with the stock diameter tubing just removing some bends and removing the silencer.
    That being said is anyone running a intake and willing to part with their stock stuff? PM me :D
  14. Oct 24, 2010 at 5:03 PM
    05RedTaco
    Tony
    Scottsdale
    You will NOT get gains in the 1-3k rpm range on an 2.7L naturally aspirated engine without forced induction. End of story.
    I rev up my engine when I have bed loaded and I am trying to get up to speed on highway. Just yesterday I had two ATV's in the bed of my 5lugger & three guys in the cab...lol Intake would help the engine breather better & accelerate better under such conditions.
  15. Oct 24, 2010 at 5:07 PM
    08pretaco
    az
    since its a week since your post have you done anything, made it yet or started thinking more into the design and such?
  16. Oct 24, 2010 at 5:12 PM
    05RedTaco
    Tony
    Scottsdale
    No because the wifey "needed" make-up, clothes, etc... :rolleyes:
  17. Oct 24, 2010 at 5:13 PM
    08pretaco
    az
    damn dont you hate that!
  18. Oct 24, 2010 at 5:15 PM
    05RedTaco
    Tony
    Scottsdale
    Life is about compromises, especially in married life. Right now main priority is ordering the Fat Bob's lift this Friday :) When i am doing the lift in my friends garage, I will take a closer look at the inatake and see if he has some parts laying around :)
  19. Oct 24, 2010 at 5:27 PM
    08pretaco
    az
    I as well as contemplating doing a custom intake with the stock air box just need a stock air box besides mine to work with :(
  20. Oct 24, 2010 at 5:38 PM
    08pretaco
    az
    there was already a huge debate on which material to use (i think it was this forum). if you do use aluminum wrap it. i know i know the air is only there for a split second so how much heat can it absorb, right? by the time the air goes through the air box, routes itself to the throttle body thats a considerable amount of time (speaking in terms of air movement) the air is prone to all sorts of ambient things hitting it.
    I mean with an ambient temperature of 76 degrees and an engine temperature of 185, my intake temps are around 90-95 degrees (ultragauge).
