2.7L MPG
Discussion in '4 Cylinder' started by dustinclm, Oct 12, 2010.
  1. Nov 20, 2014 at 9:09 PM
    #381
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
  2. Nov 20, 2014 at 9:23 PM
    #382
    knuckleduster271
    knuckleduster271 Well-Known Member
    Baron Longrod Von Hug€nschlong
    ohio
    98 sr5 xtra cab
    881's, 5100's, soft 8's, elocker, matrix seats, smittybilt xrc8.
    1998 2.7, 5 spd, 4x4, xtra cab, 3" lift, 31"mt's
    I got 15.646 from full to empty running 75-80 mph on the interstate today.
    My v8 4x4 tundra gets about the same.
  3. Nov 23, 2014 at 3:27 PM
    #383
    mshultz
    mshultz Well-Known Member
    Michael
    Wooster, Ohio
    Barcelona Red
    2014 Regular cab 4WD Automatic
    7000 miles
    19.0 mpg average
  4. Nov 24, 2014 at 5:55 AM
    #384
    rbishopp
    rbishopp Well-Known Member
    Rich
    Webster, NY
    2009 4WD Reg cab Taco. Keepin it simple.
    So far I've added an Advance folding bed cover and since removed it. Gave it to my son in Maine, he has an 05 2wd. GT perfect fit seat covers. Weathertech floor mats and window vent visors. Waag center brush/grill guard. Hose clamp tailgate mod. Turned off the seat belt chime. Added Ultra-Gauge. Trailer hitch. Softopper. Replaced sun visors with slide out style. Toyota bed extender. Had Firestone Destinations and now Michelin LTX AT2 in stock size. More mods to come; Fog lights, locking storage in bed, intermittent wipers. Now looking for Radio/HU upgrade. and maybe a lift way down the road.
    I normally get around 22 mpg. A few weeks ago I got 28 on a tank. I did the math a few times but I still can't believe it.
  5. Nov 25, 2014 at 5:31 AM
    #385
    Rackster
    Rackster Well-Known Member
    Kevin
    Connecticut
    '04 E/cab 4x4 2.7 Auto SR5
    Nice numbers Rich. I suspect your 28 came with warmer weather and better gas. The higher ethanol blends are curbing my enthusiasm.
    WW - Your tough fall/winter numbers reflect my summer bests. A real accomplishment when you think about it. Granted I have the AT but my numbers are around 22.3 these days. I never really recovered the losses from last winter (very cold in CT last year).
  6. Nov 25, 2014 at 5:38 AM
    #386
    Rackster
    Kevin
    Connecticut
    Folks with the lifts and big tires - your numbers are relative to your vehicle configurations. You may want to benchmark with a forum member here with a similar configuration. And if you aren't applying corrections relative to tire size you may be guessing wrong on your speeds, mileage, and MPGs.
    Good luck on your fuel optimization!
  7. Nov 25, 2014 at 7:19 AM
    #387
    JL911
    JL911 Psshh
    PA
    5 spd 4 bngr
    Strangely my fuel mileage has decreased with the use of non-ethanol 89. It could be coincidental as the weather is getting colder. I plan to run some ethanol laced fuel and track it to see if anything changes on my next tank.
  8. Nov 25, 2014 at 8:46 AM
    #388
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I get almost exactly the same mileage as yours. :)
    My 2012 work truck is also a single cab and always loaded down with tools and materials and hardly ever sees a freeway.
    Greg
  9. Nov 26, 2014 at 8:09 PM
    #389
    worthywads
    It must be the temperature. There is good reason non-ethanol will always give better mpg, everything else being equal.
  10. Nov 27, 2014 at 6:54 AM
    #390
    wanderingwayne
    wanderingwayne Active Member
    Wayne
    Pacific Northwest
    Stock 4x4, 3.58 gears, 30" tires, man. hub
    I have a '97 extended cab with a canopy. I do a lot of driving on back roads. Up and down hills, stop and go, in town driving a little. When I first got the truck three years ago, I was driving very carefully, trying to get the best mileage I could.
    I would average between 19 and 23 MPG a tank. At that time I was sometimes driving a lot of logging roads in low range 4WD which probably accounts for the 19.
    On the road, when I started driving with a little more foot in it, I started averaging 21 MPG pretty consistently. I was probably loosing mileage because I was lugging it to much on the hills for awhile.
    The best MPG I've gotten was 26.4 MPG on the freeway. Usually it's 25 with a few hills and some winds.
    I was surprised that I didn't see any drop in MPG when I put the canopy on.
    This might just be my imagination but, when I was keeping track of every tank, it looked like I would loose some MPG when the price of gas would take a big jump upwards????
    No difference between winter and summer driving. We have pretty mild winters on the west coast of Washington.
  11. Dec 1, 2014 at 10:51 PM
    #391
    SupremeDeluxe
    SupremeDeluxe Member
    Virginia
    Coma
    I have an 05 Tacoma access cab prerunner 4 banger. Before it was 22 mpg average both city and highway. I got a tune up replacing all the fluids, filters, etc. and now achieve 24 mpg. I also baby the vehicle but I'm going for mileage most of the time.
  12. Dec 2, 2014 at 8:11 AM
    #392
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    The ethanol "blended" fuels are more expensive to produce and have slightly less energy content.
    That is super cool! :D
  13. Dec 19, 2014 at 2:20 PM
    #393
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Im getting 18 with 4:30 gears and 265/75 and a 5spd 4x4. I shift around 3k and sometimes around 2500 and 80%hwy driving.
    The truck did come with k&n drop in air filter, not cai, and it has 160k miles so I don't know if all the necessary things have been changed like spark plugs and all the oils.
    Any ideas on how to get better? id like to see 20 but im an extended cab and 4x4.
  14. Dec 27, 2014 at 3:32 PM
    #394
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
    2013 AC 2wd auto trans., no camper top @ 5010 miles
    stock Dunlop AT20s: 30 psi front, 33 psi rear
    90% city 10% highway
    no towing, no heavy loads
    all near sea level
    driving habit: moderate- neither gearhead nor grandpa
    19.2 miles/gal.
    A drop of almost 2.8 mpg since last post; although 10% increase in city mileage, would that account for a 2.8 mpg drop? Maybe winter blend, other threads/posters have suggested such.
    Have increase all tires to 35 psi to see if I can eke out more mpg.
  15. Jan 3, 2015 at 9:57 PM
    #395
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Bone stock 2014 regular cab 4x4 5 speed and I average 22mpg. That is probably 50% city/50% highway. All highway I get around 24mpg, not sure what all city is.
  16. Jan 5, 2015 at 8:13 PM
    #396
    electrictaco
    electrictaco Member
    BC
    2020 Tacoma TRD off road AT
    canopy
    I have gotten anywhere from 21 to 28 MPG. It seems the best mileage is when I go on a fishing trip into the hills. This involves driving about 180 K on pavement and about 30 K on decent logging roads and paths through the woods in a mix of of running 4 wheel drive high and low range. Every time I do this run I get excellent mileage. GO FIGURE!! I have a stock 2.7 Access with 265/75/17 rubber and a 5 speed. I love driving this rig in 4 low. It is perfect for the ups and downs in the Vancouver Island mountains.
  17. Jan 9, 2015 at 9:12 AM
    #397
    Indy
    Indy Master of all I survey.
    Steady driving helps mpg, but so does keeping the engine in the powerband instead of lugging it all the time. Hilly and down a gear keeps the engine running where it's actually making power instead of just turning gas into emissions.
  18. Jan 10, 2015 at 7:49 AM
    #398
    Rackster
    Kevin
    Connecticut
    Jacob - it may be a mix of things clipping you top FE. Try dropping your RPMs at shifts, coasting on flats and down hills. Also, level load your foot on the gas peddle meaning find a sweet spot and keep it steady. Level loading is typically more efficient than cruise control. You may opt to create a Warm Air Intake (not a CAI, but a WAI). You can do this relatively cheaply by buying a 90 degree elbow, corrugated hose to match, and a metal exhaust coupling. Disconnect the standard intake piece between the fender wall and the air filter box. Put the 90 deg elbow on the box, connect the tubing and route the line back towards your exhaust manifold. I connected the metal coupling to the end and pointed downward at the manifold. In winter, I pull air that's 30 degrees warmer than outside the engine compartment, run leaner, and improve FE. I haven't noticed much if any power loss.
    With your manual transmission and assuming your terrain/temps are similar, I'd guess you should be pulling in the low 22s. Lots of other tricks to learn if you browse CleanMPG.com. Good luck!
  19. Jan 23, 2015 at 3:21 PM
    #399
    TacoGlenn
    PNW
    '13 MGMAC 2.7L SR5
  20. Jan 24, 2015 at 9:50 AM
    #400
    jibski
    jibski Well-Known Member
    Josh
    Arvada, CO
    2009 Silver 2.7 AC 4X4
    Picked up my '09 4x4 manual AC a few months ago. Initially I was getting around 19mpg. For the entire last tank, I subscribed to the "shifting at 2000-2500rpm" process and have been keeping my rpm's generally below 2000. I also greased my drive shaft just before that tank at 50K miles (probably the first time it's been done since new). This last fill-up I was right at 23.5mpg!! Mix of city and highway. Needless to say I was pleasantly surprised. Next I am swapping all the tranny, x-fer case, and diff fluids to redline synthetic. Hopefully I'll continue to see good fuel economy!
