2.7L MPG
Discussion in '4 Cylinder' started by dustinclm, Oct 12, 2010.
  1. Jan 24, 2015 at 12:39 PM
    #401
    JL911
    JL911 Psshh
    PA
    5 spd 4 bngr
    The biggest contributor to your increase in mileage IMO is the low RPM habit. I changed all my fluids to synthetic and greased the drive line and did not notice any increase in fuel economy. It did drive smoother after doing all that maintenance though. It's certainly worth doing.
  2. Jan 28, 2015 at 7:00 AM
    #402
    Texasdynaryder
    Texasdynaryder Well-Known Member
    Chance
    Paris, Tx
    Kings Built Engine All the other small goodies
    Stock 2003 2.7l 4x4 manual. Don't really drive in the city but a ton of lease roads etc. Last hwy trip got 22.6 mpg but my Average is between 17-19 most of the time. I have a lot of idle and stop and go. I make shifts about 2000 to 2500. Running 265-75-16 tires also.
    Will be adding an OME lift kit. Will report back with numbers in the next week or two.
  3. Feb 17, 2015 at 12:09 PM
    #403
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
    2013 AC 2wd auto trans., no top @ 5293 miles
    stock Dunlop AT20s (P215/70R15): 35 psi front, 35 psi rear
    90% city 10% highway
    no towing, no heavy loads
    all near sea level
    driving habit: *GGDRS #5-6
    20.47 miles/gal.
    *http://www.tacomaworld.com/forum/per...reporting.html
  4. Feb 17, 2015 at 4:09 PM
    #404
    allen993
    allen993 Well-Known Member
    Allen
    Alabama
    2019 TRD Off-Road, Access Cab, Cement
    I have a '14 base AC, 2.7L, with 15" steel wheels. I commute every day 52 mile to and 52 miles back...75% interstate at 80mph...the other is fairly heavy stop and go traffic. I get combined 24 mpg. Saw others added tire pressure, so here's mine: F = 33psi, R = 36psi.
  5. Mar 13, 2015 at 8:39 AM
    #405
    TacoAppetite
    TacoAppetite Member
    Nick
    Steelville, MO
    Plain Jane '99 SR5
    STOCK
    1999 SR5 Access Cab 2.7 5 speed. I manage a high of 27 on the highway and 24 in the city but have a ton of long hills to coast down, running small highway tires, and a broke 17 year old. The whole truck is completely stock
  6. Mar 17, 2015 at 7:14 PM
    #406
    Winning8
    Winning8 Member
    Tom
    CA, 94546
    13 base
    stock 13 base AC 2.7l auto...long trip I could get 28mpg which is about 90% freeway cruising it at 60, make sure it never went pass 2G rpm and never change throttle position, so driving uphill is a drag only could go 45-50 mph, and let it roll downhill...
    around town or about 60% freeway, I could only get 24-25mpg.
  7. Mar 26, 2015 at 5:02 PM
    #407
    TacoGlenn
    PNW
    '13 MGMAC 2.7L SR5
    2013 AC 2wd auto trans., no top @ 5382 miles
    85% city 15% highway
    all near sea level
    22.35 miles/gal.
  8. Mar 31, 2015 at 6:16 PM
    #408
    01TacomaExtCab
    01TacomaExtCab 01 Tacoma
    Nate
    Pennsylvania
    2001 ext cab tacoma impulse red 5 speed sr5
    K&N Intake, Skyjacker 8000's, Westin Bull Bar
    01 Tacoma access cab l4 I shift at 2k rpms get 15mpg city. Stock height stock tires. K&n air filter. Any ideas to get better mpg?
  9. Apr 1, 2015 at 3:02 PM
    #409
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    No jack rabbit starts. Watch ahead for light changes, etc., and back off the small pedal when necessary. Every time you use the brakes to slow down you are essentially wasting energy provided by your fuel. Ensure your tire pressures are correct. High pressure generally yields better gas mileage, but too high will cost more in tire wear. Narrow tires generally give better gas mileage than wide ones. Is your engine due for a tune-up? I have read negative comments about K&N air filters--too much oil fouls up a sensor. That might be relevant. Your shift points are correct, at least in my experience.
  10. Apr 2, 2015 at 4:19 AM
    #410
    jfriess128
    jfriess128 JAF128
    SW Florida
    2015 PreRunner, Double CAB, SR5
    I have a new 2015 2.7L double cab pre-runner, 2.7L. The first tank was 19.4 and the second was 18.7. Both mostly city driving. I would hope it would get a little better city mpg after the engine in broken in.
  11. Apr 2, 2015 at 5:04 AM
    #411
    Rackster
    Rackster Well-Known Member
    Kevin
    Connecticut
    '04 E/cab 4x4 2.7 Auto SR5
    I'll echo AZ's advice. Stock/near stock Tacomas should yield better MPGs if you're driving sensibly. This is especially true of manual transmission configured vehicles. The only time I'm in the teens for FE is when I spend time in 4x4.
    Warm weather and reduced ethanol blends will help restore FE. I'm happy for that. Re the K&N filter there are mixed reviews. The oil type air filters receive worse press than the dry. Personally I wouldn't opt for either. Stick with OEM equipment and replacement parts is my suggestion. Same is true with exhaust systems unless you really do your homework and do your own tuning. Most folks are under the assumption that if they buy a CAI and loud exhaust things will improve. It usually makes matters worse regarding FE and any power gains modest at best but mostly negligible.
    With that said owners are welcome to configure their vehicles without our judgment. I like lifts and big tires for instance, both of which diminish FE. But you need to be happy with what you are driving. So sacrificing some FE is probably worth it. I stated my comments because many are swept up by manufacturer's claims which are often inflated or out right lies with regards bolt on performance or snake oil. Optimizing FE is work and sometimes hard work. It is also good, and for me, important work. What's better than driving what you want at the performance and FE levels you desire? Sounds like win-win-win. Hard to achieve but if you do, very satisfying. Good luck on your individual projects!
  12. Apr 2, 2015 at 8:12 PM
    #412
    arpiti
    arpiti Member
    Tony
    Chantilly, VA
    04 Tacoma 4x4
    2004 Tacoma with 2.7L. All stock parts. I drive in the D.C. metro area, and have been keeping a fuel log for about two years now. Getting 19.3 MPG overall, which seems to be in line with what other folks are posting.
  13. Apr 5, 2015 at 5:04 PM
    #413
    gazingwa
    gazingwa Well-Known Member
    Slower Lower Delaware
    15 PreRunner Doublecab 2.7
    OEM: Backup Camera, Bed Mat, Wiper Switch. Aftermarket: Fog Lights, Pop and Lock, Truxport, MS2's Debadged
    Just pulled 25.6mpg on a 60mph sea level trip. 22.9 overall and it's only getting better now that it's warmer.
  14. Apr 5, 2015 at 5:28 PM
    #414
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    My previous Taco was standard cab 4wd 5 speed 2.7. Best off road truck I ever owned including the off road model I have now. It did average 21/22 mpg overall but seldom any higher. On trips it could go as high as 24 plus if I kept the speed sane and below 65 mph. Over that, it was 21/22 max. Towing a boat, it was worse then my six. It was a great motor in this lighter truck with a standard. Previously, I had it in 2wd. Solid 25 mpg on trips was not unusual even at higher speeds.
  15. Apr 10, 2015 at 9:08 PM
    #415
    GEORGE STRAIT
    GEORGE STRAIT (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    My old commute was like 4 miles, all start and stop with a bunch of redlights. It never got to stay at a constant speed and I would get like 16. Now my commute is much longer and I basically run 40 mph for about 15 miles at a time. My last 6-7 tanks have been 20-21. I get 20-21 highway as well running at 70. Can't really complain. My record is 23 mpg city.
    Oh yeah my specs are: 2014 4x4 auto with 2.5 inch lift, 33's, and a bestop soft topper
  16. Apr 11, 2015 at 11:03 AM
    #416
    Mongo1958
    Mongo1958 Well-Known Member
    Van
    Newnan, GA
    2015 Bright White Access Cab w/convenience pkg.
    Carbon filter removal. Intermittent Wiper Stalk. Cruise Control. Fog Lights.
    My Taco is a base access cab and I'm getting 23-23.4 with highway speeds up to 80+MPH and I often use cruise control when going to work. going home is like a NASCAR event. I live on the south side of Atlanta with some hills, not flat but not full of crazy hills either.
    Edit note: I have a 4 speed auto trany and 90% HWY.
    gofas likes this.
  17. Apr 26, 2015 at 3:10 PM
    #417
    TacoGlenn
    PNW
    '13 MGMAC 2.7L SR5
    2013 AC 2wd auto trans., no top @ 5531 miles
    all near sea level
    19.63 miles/gal.
  18. Apr 30, 2015 at 7:15 PM
    #418
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    Just back from a long trip and got 22.6 with cruise set on 60 mph. I think it is the best I did on highway. Mix is around 20-20.5 if I am kind with it.
  19. May 6, 2015 at 10:50 AM
    #419
    Red_Taco33
    Red_Taco33 Well-Known Member
    Upstate New York
    2021 TRD Off-Road MT
    I probably get around 14-15, mines lifted with 35's tho.
  20. May 19, 2015 at 11:50 AM
    #420
    JL911
    JL911 Psshh
    PA
    5 spd 4 bngr
    Do you have a lift or off-road tires? My stocker came in around 25 MPG on highway at approximately the same speeds.
