2.7L skid options
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 1776Taco, Oct 18, 2020.
  1. Oct 18, 2020 at 10:18 AM
    1776Taco
    1776Taco [OP] Well-Known Member
    2019 2.7 4x4 SR
    added rear seats access cab LEER 100R Curt hitch receiver Curt trailer lights Carthart seat covers 255/85/16 Toyo MT for trails 265/70/16 W/ OR wheels for DD TRD PRO skid OR fuel tank skid Warn tubeless winch bumper Smittybilt XRC 9.5k winch HS 1/4 inch coil spacers RCI rock sliders Wheelers 1.5 AAL Bilstein 5100 rear Decked
    Need some skids. Not finding to much info on 3rd gen 2.7s only the V6s. I’m wondering , if I buy a TRD PRO front skid to put on my SR will I still have access to my oil pan drain plug? If I have to drill a hole for it , it’s not to big of a deal but I’m definitely not going to remove it everytime I have to change my oil. Also, if I do get the pro skid , think I could maybe buy an aftermarket plate for the trans and use with the pro? Any tips and advice is much appreciated.
  2. Oct 18, 2020 at 10:21 AM
    whatstcp
    whatstcp currently drunk so don't listen to me
    Ed
    Fontana, CA
    2006 Tacoma Regular Cab 2.7l 4x4
    King + Archive Relocation Wheeler's bumps +hydros
    V6 skids perfectly fit the 2.7. completely interchangeable. drain hole is exactly the same. Only difference is the oil filter access panel
    Skydvrr and 1776Taco[OP] like this.
  3. Oct 18, 2020 at 10:36 AM
    1776Taco
    2019 2.7 4x4 SR
    With the pro skid or any aftermarket skid is it still possible to get to the oil filter
  4. Oct 18, 2020 at 10:42 AM
    whatstcp
    Ed
    Fontana, CA
    It'll be the same as it is now with the stock splash shields. No more or less access. So whatever you do now, it will be the same
    1776Taco[QUOTED][OP] likes this.
  5. Oct 18, 2020 at 10:46 AM
    1776Taco
    2019 2.7 4x4 SR
    Sweet. Thanks. Also, would u happen to know if I got the pro skid would it work with an aftermarket trans and t case plate ?
  6. Oct 18, 2020 at 10:47 AM
    1776Taco
    2019 2.7 4x4 SR
    I’m sure it would and I’m also sure these are dumb questions but I just want to make sure before spending all this money
  7. Oct 18, 2020 at 10:57 AM
    whatstcp
    Ed
    Fontana, CA
    Not dumb questions, especially when it means potentially buying something that costs hundred of dollars and might not fit. You gotta double check before you swipe the card, can't blame you for that.
    From what I recall, only pelfreybilt and rci used to make compatible skids with the trd pro one. Also, I'm not even sure if your 2.7 will work with full skids since the transmission length might be different and potentially the transmission crossmember might not the in the same location. For that question, you'll have to contact someone who makes aftermarket skid plates or find another 3rd gen 2.7 owner (hopefully one will chime in here). I can only confirm that the front skid plate is compatible between 3.5 and the 2.7
    Also, the trd pro skid plate is really nice but a bit overpriced IMO (even though I have one on my 2.7 lol). If you wait about another month you might be able to get an aftermarket skid plate for significantly cheaper due to black Friday sales.
    9th, 1776Taco[QUOTED][OP] and Skydvrr like this.
  8. Oct 18, 2020 at 10:59 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Good attitude buddy :thumbsup::thumbsup:
  9. Oct 18, 2020 at 6:33 PM
    Fleischwagen
    Fleischwagen 2.7 > 3.5
    North Jersey
    2017 SR 5MT 4X4
    5.29's, ARB locker, 6112/5100, Deaver AAL, LCE Header, aFe dry-flo filter, Hurst/Core shifter, CBI T3 Front, Warn Winch, CB/UHF Radio equipment, Backrack, KC fogs and spots
    I have a TRD Pro skid on my 2.7 truck, fits no problem. I have one of those oil drain valves with a short rubber section so I can drain the oil extremely easy. As for the filter, I just cut the top of a windshield washer bottle and stuff it under the filter and spin it off, let everything drain into the impromptu bucket and grab it from the side. No need to remove the skidplate, no mess :thumbsup:
    As for the trans skids, I'm not sure. I have a 5 speed so that may change the result as well. It sits pretty high so I haven't really needed one just yet. I'll probably make something up at work
    1776Taco[OP] likes this.
  10. Oct 18, 2020 at 6:51 PM
    1776Taco
    2019 2.7 4x4 SR
    Great! Thanks for the response. I’ll probably wind up buying the pro skid and then a aftermarket trans plate
  11. Oct 20, 2020 at 4:59 PM
    Fleischwagen
    North Jersey
    2017 SR 5MT 4X4
    Just beware, it mayyy be different, im sure someone on here has tried it before. Also, I'm not entirely sure that the TRD pro skid plate is compatible with some aftermarket trans skid plates, I'll be checking here to see what others have found hah
  12. Apr 12, 2022 at 2:26 PM
    hella_tacoma
    hella_tacoma Well-Known Member
    San Francisco, CA
    2020 SR AC 2.7L Black
    want to resurrect this thread, have 2.7, and cross member 2 inches further than on v6, so I can make RCI T case skid fit with two holes drillled and engine skid will fit, but will have to fab sheet of metal for transmission skid, I really just need sheet metal. Wanted to ask, is the access to oil same as on V6 meaning did TRD pro skid plate work fine on 2.7L ?
  13. May 10, 2022 at 6:02 AM
    jeffmansion
    jeffmansion Well-Known Member
    16UTILITY4x4MT2.7
    K&N 63 series CAI, AVS Vent Visors, 16x8 Level 8 MK6 Rims, 285/75/16 MT, Eibach Pro lift, JBA UCAs, Wheelers 3leaf AAL, RokBloks XL mud flaps, DV8 skidplate, Westin bedmat, Backrack, swaybar delete, Magnaflow cat-back, 9Drive throttle controller, 2LO Mod, Cali Raised Sliders, Tyger rear bumper, Avid front bumper guard.
    bump. I am also looking for more skidplates on my 2.7.
    I have the DV8 under engine skidplate, and RCI A Arm skids.
    I want to continue them and add the trans skidplate etc. I spoke to RCI and theirs will not work with mine, only 3.5 v6.
