2.7l True Custom Intake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by no_werries, Sep 28, 2008.
  1. Sep 28, 2008 at 6:53 PM
    no_werries
    no_werries [OP] Well-Known Member
    Simcoe County, Ontario, Canada
    2005 4x4 reg cab Indigo Ink 5 speed
    CAI, 2 1/2" rear lift AAL, Ready Lift strut ext. & diff drop = 2 1/2" front lift, tweaked clutch, Magnaflo Muffler & Custom exhaust 265/75/16lt Nitto Terra Grappler 8ply on stock rims. Huskyliners
    Was helping a friend move today when I seen an intake tube that used to belong to an old honda civic, well the gears got craking in my head and this is what they grinded out
    I had to cut the intake down to fit in length, I was able to use the original rubber hose from the intake box to clamp the one end on, there is no hose clamp on the one end cause there is no need, I had to throw the rubber hose in the microwave for 30 seconds so I could stretch the rubber around, I then just drilled a hole for the valve hose, and there was another small rubber hose coming off the stock intakes reisonator so I drilled a hole for that to, and this is what I got!
    BTW I have a drop in K&N air filter all ready, sounds beefier when I lay down on the gas, maybe a little improvement in throttle response, might all be in my head! I have a cone for the end that I was able to cut a slot for the mass air flow sensor into the side of the rubber neck, so I could throw that on, but I like the fact the I could keep the stock air box, tell you the truth I dont think this is far off from how a Volant is designed!
  2. Sep 28, 2008 at 6:56 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    cool and creative mod bro!!! good job......and now you have a high flow tube!!! i like it!!:)
  3. Sep 28, 2008 at 7:06 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    cool. good build.
  4. Sep 28, 2008 at 7:08 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Reduce, Reuse, Recycle-
    Good on you for putting a lil extra effort in to make your truck really yours.
  5. Sep 28, 2008 at 7:19 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well said buddy!!:)
  6. Sep 28, 2008 at 7:22 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Put a hose clamp on the other end anyway. It can loosen up and can also pull loose with engine movement.
  7. Sep 28, 2008 at 7:27 PM
    no_werries
    well noted, I had already planned on doing that, just I burned the midnight oil on this project and didnt have one big enough!, gonna stop by Canadian Tire tomorrow and pick one up!
  8. Sep 28, 2008 at 7:37 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Good job, btw. Good to see folks using their skills.
