2" leveling kit?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mbaltonv, Feb 6, 2008.
  1. Feb 6, 2008 at 11:30 PM
    mbaltonv
    mbaltonv [OP] Active Member
    Moscow, ID
    02 extra cab manual 4x4 TRD
    Front Bilstein 1500's 2.5", 1.24" rear schakel, 2" rear AAL, Swaybar disconnect, 265X75R16 BFG T/A ko
    Has anyone had any problems with 2" leveling kits on Tacomas. I have heard that going over 2" can result in excess CV wear. Any help.
    Thanks
    -Matt
  2. Feb 6, 2008 at 11:56 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    2" should be OK, going 3" is maybe going the limit with your CV's.
  3. Feb 7, 2008 at 8:38 AM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    i have 3in with 1in diff drop so its acting like i have a 2in lift
  4. Feb 7, 2008 at 9:00 AM
    mbaltonv
    Moscow, ID
    What about using add-a-leafs in the rear, any problems?
  5. Feb 7, 2008 at 9:02 AM
    2003greenbean
    socaste,sc
    03 trd
    no rpob for me a little rough at first but after a couple weeks they get better
    did the schakel get in the way of the tail pipe what kind of sway bar disconnect do you have
  6. Feb 7, 2008 at 12:30 PM
    mbaltonv
    Moscow, ID
    The shackle did so I just cut the tail pipe off where it turns down over the axle. Slightly more noise but I think it sounds better. The sway-bar disconnect is homemade and on my taco I had do build a homemade mount that was mounted on the sway bar. With that I was able to fun a l shaped piece of medal down to the mount on the lower control arm, where I have a lynch pin holding it in. It wasn't too hard to make and works extremely well. My truck flexes in the front better than some solid-axle vehicles I have seen.
    Has anyone had any axle wraping problems with 1" blocks? Also any one run 33" mudders? Notice any major changes in gas mileage?
  7. Dec 17, 2010 at 3:02 PM
    beacher
    beacher Well-Known Member
    09 TACOMA 4x4
    2" spacer lift in front end bf goodrich allterrain tires custom exhaust system tinted windows smelly interior
    IM HAVING A PROBLEM.. i installed a 2'' leveling kit in the front of my tacoma . it was a pain in the ass puting it in. i have an 09 tacoma btw. since i installed it, ive had a weird vibration thats noticeable when driving down the road. and theres sort of a wobble i cant figure out what it is.. any suggestions? i already got the alignment done.
  8. Dec 17, 2010 at 3:06 PM
    Dibblit
    Dibblit Eh?
    Paul
    Fort McMurray
    11 Tacoma
    OME suspension ARB OBA ARB locker
    check your drivline angles, you may need to shim
  9. Dec 17, 2010 at 3:08 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Top plate spacer or coil spacer? I'm guessing coil since you said it was a PITA.
    First thing to do is re-torque everything in case it shifted after settling.
  10. Dec 17, 2010 at 3:20 PM
    beacher
    09 TACOMA 4x4
    top plate spacer
  11. Dec 17, 2010 at 3:31 PM
    beacher
    09 TACOMA 4x4
    i willl try and take some pics and post em up here. i dont like the leveling kit. and i dont have much money. due to payments .. but does anyone have the billstien 5100s? had the tsb done
  12. Dec 17, 2010 at 3:32 PM
    TexasTacoma37
    EVERYONE has the bilstein 5100's.
  13. Dec 17, 2010 at 3:44 PM
    beacher
    09 TACOMA 4x4
    haha yeah , but how are they? how well do the perform offroad?
  14. Dec 17, 2010 at 3:48 PM
    TexasTacoma37
    A quick search will give you hours of reading material.
  15. Dec 17, 2010 at 5:12 PM
    beacher
    09 TACOMA 4x4
    yeah, nice truck btw
  16. Dec 17, 2010 at 5:17 PM
    beacher
    09 TACOMA 4x4
    just checked the driveline angles, they are off a bit
    im no machanic..haha. do i attempt it? or should i go to an auto machanic? i dont want to mess up anything in the front end. thanks for the reply
