2 LO MOD
Discussion in '1st Gen. Tacomas (1995-2004)' started by toyotadan98, Nov 11, 2012.
  1. Nov 11, 2012 at 6:50 AM
    toyotadan98
    toyotadan98 [OP] Well-Known Member
    wa
    2011 TRD OFFROAD 4X4 ACC
    I found this mod on another site i couldn't find it here :eek: All you have to do is unplug the blue plug on the driver side of the tranny ??? thats it ???? I want to do it ! I know someone on here will know.:cool:
  2. Nov 11, 2012 at 7:03 AM
    Madjik_Man
    Colorado Front Range
  3. Nov 11, 2012 at 7:34 AM
    toyotadan98
    wa
    i allready done the grey wire mod and it works great , this is the 2 lo mod .
  4. Nov 11, 2012 at 7:43 AM
    toyotadan98
    wa
    I first found yotatech and on there i found the wattora. Washington chapter Ya the great northwest and i found this info there just wanted to back it up on here thats all before i do it .
  5. Nov 11, 2012 at 8:11 AM
    toyotadan98
    wa
    2 LO MOD HOW IS THAT VAGUE ??? WTF.
  6. Nov 11, 2012 at 8:19 AM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    I think he's talking about running the transfer case in 2wd low.
  7. Nov 11, 2012 at 8:22 AM
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    What r the benefits of being in 2wd low?
  8. Nov 11, 2012 at 8:26 AM
    toyotadan98
    wa
    It is pretty clear 2 LO MOD of course its the transfer case. I just wanted to cross reference the info i found on a different above mentioned site thats all. If you have info please reply if not go else where on here!!!!!
  9. Nov 11, 2012 at 8:29 AM
    tomtom
    The Desert SW
    2012 FJ
    if you need the torque of low but making tight maneuvers where the driveline may bind up.
  10. Nov 11, 2012 at 8:33 AM
    joes06tacoma
    Joe
    Central Coast, CA
    http://www.tacomaworld.com/forum/1st-gen-tacomas/162032-2low-mod-push-button-4wd.html
    I don't have a first gen truck to verify, but looks like this only works if you have the push button on the side of the 4wd shifter. Unplug that connector, and the truck will not automatically shift to 4wd when moving the lever into low range. 4wd still works fine, just have to push the button.
    If you have a manual transfercase that requires you to move the lever for 4wd (no pushbutton), this mod won't work.
    Grey wire mod is for the rear diff locker to work without being in low range.
  11. Nov 11, 2012 at 8:35 AM
    dayNnite4
    Nick
    Southern NH
    '11 4x4 5-speed AC
    Ohh gotcha
  12. Nov 11, 2012 at 9:05 AM
    toyotadan98
    wa
    I have the push button I was just looking to clarify info thats all 2 LO MOD.
  13. Nov 11, 2012 at 12:22 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
  14. Nov 11, 2012 at 12:47 PM
    ckblum
    ckblum Well-Known Member
    Cam
    Chilliwack, BC
    Tacoma
    Bilsteins, Light Racing UCA's, Alcan's, Kragen HID's
    So it's pretty much like doing a twin stick but half electric and infinitely cheaper?
    boshak likes this.
  15. Nov 11, 2012 at 12:54 PM
    toyotadan98
    wa
    ya what you said:eek:
  16. Nov 11, 2012 at 4:20 PM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    From what I've read in the past, the 2 low mod turns off the add on one side allowing all of the power to be put to that side. It only works if you have an open diff in the front. Your driveshaft still spins as if you are in 4wd. I don't remember the procedure for doing it, so I can't really help you there. But from what I remember you have to cut a wire and install a toggle switch so that when you put it in 4 low, you flip the switch to disengage one of the front axles and then it goes into 2 low.
  17. Nov 12, 2012 at 5:39 AM
    Snorkie
    Snorkie JEEP LYFE
    Jeep
    Rubicon
    Prius
    If you unplug the connector it probably disconnects the actuator that switches it to 4wd. (Depending on what transfer case you have) so when u put ur shifter in 4 low ur only really getting 2 low.
    If u have a J shift transfer case you can get twin sticks that will let you control 4wd separate from low/high.
  18. Dec 2, 2012 at 12:47 PM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Just finished the 2 Low mod on my 1996 Manual Transfer Case.
    Simple wiring of a switch into the 4WD indicator wiring, and there ya go, 2WD Low.
  19. Dec 19, 2012 at 6:17 PM
    Enigmaaron
    Enigmaaron All your soul are belong to us
    PA
    1st gen superiority
    ^^^ 100% correct. From someone with a push button 4wd 1st gen who has done this mod.
    The connection that gets unplugged is just a signal wire from the transmission to the transfer case that tells it to engage 4wd when you shift into low. Disconnect it and now you fully control when 4wd activates by pressing the button.
  20. Dec 19, 2012 at 6:35 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    I knew exactly what OP meant by reading the title. I did it to my truck day one and its been useful (and free).
