+2" Long Travel kit + SUA underbed - Shock sizes??
Discussion in 'Long Travel Suspension' started by Only Danks, May 26, 2013.
  1. May 26, 2013 at 12:52 AM
    Only Danks
    Only Danks [OP] TRUKWERX : Desert Racing Products
    Bryant
    San Diego, CA
    05 Black TRD O/R 4x4
    3" MID-TRAVEL LIFT: Fox 6x2.5 Front RR C/O's, Fabtech unibal UCA, Fox 10x2 Rear RR Shocks, All-Pro Leaf Pack, Fox 2x2.5 Air Bumps all 4, Strapped all 4, TC Gussets:, Lower Arm Cam Tabs, Front C/O Bucket Tower, Spindles, OTHER: Custom Front Bumper skid, Custom Rear Tube Bumper, McNeil Racing 3" Fiberglass Fenders, McNeil Racing 4" Fiberglass TT Bedsides, 2 Matching Vertical Spares, GrillCraft black mesh, 07 LED Tails(black), Headlights (black), Viper 5204 Alarm, Remote Start, Cobra 19 CB Radio, 6 ft Red LED Firestick Whip, High-lift jack, Black Emblems, STEREO: Custom Nexus7 inDash, Rockford 3sixty.3 to SPDIF, Rockford T1 6.5 Comp Front, Rockford T1 6x9 rear, Rockford PBR300x4 Amp, Rockford P310 (x2) rear seats, Alpine 1100w amp, USB DAC via SPDIF, USB Audio ROM, FUTURE MODS: TC +2" LT Kit, 8" LT Coilover, 16 Rear Piggys, L/T CV Axle Shafts, Heim Steering, DMZ SUA kit, Bedsaver cage, Shackle Crossmember, Motor Mount Gussets, Box Frame
    Im considering the TC +2" LT kit for my 05 4x4 DD. Hoping to get input and a few questions answered by those with experience.
    My first questions seems silly but like the title says.. What size coilovers are you running with the +2" LT kits?
    For the rear im thinking SUA kit like giant but could i keep it under the bed?
    Anyone had experience with this kits? it advirtises 15" travel w/ 33"s w/ stock bedsides.
    http://www.definedengineering.com/products.html
    How long of rear shock should i use? i will be going with king w/ res w/o bypass.
  2. May 26, 2013 at 1:27 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Read the sticked threads and use the search function. There are several threads that discuss the defined kit.
  3. May 26, 2013 at 6:37 AM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    Total Chaos specifies the correct part number for a shock that works with their kit. I wouldn't try and use a shock that you have on the shelf because you probably won't get the most from your kit.
    You can run a Giant , DMZ, or Defined kit under the bed but you won't get the travel numbers that the kit is capable of. There are multiple people on here with these kits and many different rear shock lengths. Every bed cage or shock hoop is going to be different.
    There is a ton of info in the various threads as well.
  4. May 26, 2013 at 8:10 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    I'm running the defined kit with shock hoops and kings built to spec for the hoops, i have 13" of travel in the rear, may not be that much compared to some but it works well for me!
  5. May 26, 2013 at 11:45 AM
    Only Danks
    Bryant
    San Diego, CA
    Thanx, iv actually read your posts, among the many others. Did you decide against the defined kit?
    hmm having trouble finding that still
    Are your hoops through the bed? What length kings?
  6. May 26, 2013 at 12:16 PM
    PLC721
    Patrick
    Chandler, Az
    No they are not, i didnt want a set up that loses bed space. Like 11" stroke
  7. May 26, 2013 at 9:40 PM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    Your right about the mystery since its not listed on website like their other kits. Call Pat at Total Chaos to get clarification on Tues.
  8. May 26, 2013 at 9:57 PM
    Only Danks
    Bryant
    San Diego, CA
    Kool pretiate the info man
    Ah yes that was the defined kit i posted, sorry so many bookmarks lol
    i also stumbled across this "sky manf." kit,
    http://www.sky-manufacturing.com/new/detaproduct.php?id=271
    Is it meant to run under axel? Since hoops underbed wont get the full #s with the 3 major kits, i was thinking this might be ok.
  9. May 26, 2013 at 10:24 PM
    Only Danks
    Bryant
    San Diego, CA
    i noticed they dont offer shock hoops, did u buy or make some? im hearing TC discontinued the 2.0 5lug ones due to failure since they wernt linkd
    i also stumbled across this "sky manf." rear LT kit, with 56" spring instead of the 64" deavers.
    They call it a rear LT kit but not SUA. Is it meant to run over axel?
    Thinking since hoops underbed wont get the full #s with the 3 major kits, id go with this 54"SKY kit, ditch the 5100s, find shock hoops to use w/ a 2.5" king piggy( maybe 12")?
  10. May 26, 2013 at 10:28 PM
    PLC721
    Patrick
    Chandler, Az
    Had a buddy build me some
  11. May 27, 2013 at 2:55 AM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    I would stay away from that Sky manf kit if I were you. Relocating the front hangars is required which is a lot of work that is not easily transferable with another kit. I also wouldn't run a kit that's not proven by multiple people and all issues are worked out.
    People are pulling 10" of travel with All Pro standard 3" leaf springs and extended shocks in stock locations. Or Defined Eng like nofords08 and getting 13" of travel with relocating to SUA but not moving front or rear hangars.
    I wouldn't move your front or rear hangars unless your sure that's the kit your going to stick with. Do you have the fab skills to do this yourself?
  12. May 27, 2013 at 3:10 AM
    Mxpatriot
    I bought Krish's old defined kit, but I'm deployed, so I haven't seen it yet. I had family in the area pick it up for me.
  13. May 27, 2013 at 12:00 PM
    Only Danks
    Bryant
    San Diego, CA
    Hangers stay, ok. thanx for pointing that out. I agree on the race proven thing. How do you feel about relocating shock hoops like BAMF. i was thinking upper but i didnt consider the lower one on the axel
    http://www.tacomaworld.com/forum/ba...-m-f-2nd-gen-rear-shock-relocation-kit-7.html
    I dont have fab skills, im looking to stay primarily bolt on, but if the BAMF hoop is all the fab needed, a buddy has a garage.
    Right now im leaning toward TC +2" LT Front, Defined SUA Rear w/ BAMF rear hoops.
    Have connect @ king but need to figure out what length shocks i need now lol. Only suggestion iv got is to measure when everything else is installed.
  14. May 27, 2013 at 10:41 PM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    There are may be a few running the BAMF towers with the Defined kit but there isn't much info out there on their experiences I've seen or read about. Keeping the shocks under the bed and going SUA is a challenge. It's more experimentation/hassle than a 62" SUA leaf pack from DMZ that is proven to work with a simple bed cage and 16" shocks.
    If you want more than 10" of travel but want to stay under bed then go Defined. If you want a full LT rear go DMZ or comparable 62" kit but get ready to cut your bed up.
    Cantilever is an option as well to research. It allows you to get max travel under the bed but its complicated and has to be set-up correctly. 62" kits are simple and less hassle/expense.
  15. May 29, 2013 at 5:29 PM
    FixedTRD
    FixedTRD Well-Known Member
    Will
    Alhambra, CA
    All pro LT, All pro front bumper,All pro rear fox, 1.5 full leaf and u bolt flip kit. KR sliders, bestop, high lift with custom mount, katskin leather, Hankook MT and atx artillery. DMZ SUA w/FOX triple bypass
  16. May 30, 2013 at 8:49 PM
    Redgrom
    Redgrom http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
  17. May 30, 2013 at 10:01 PM
    FixedTRD
    Will
    Alhambra, CA
    That's awesome Brent can't wait till your truck is done you'll love it.
    I know of another member on here that's getting the same setup with
    some killer bling. His is going to be pretty sweet. :)
  18. May 30, 2013 at 10:02 PM
    rcfreak201
    rcfreak201 Well-Known Member
    I think I know who your talking about, I hope it sees dirt :D
  19. May 30, 2013 at 10:06 PM
    FixedTRD
    Will
    Alhambra, CA
    Hahah :D I know you know who it is, some killer components from what he told me. Going to be too pretty to see dirt .
  20. May 30, 2013 at 10:20 PM
    Redgrom
    Brent
    san clemente
    Now i'm very interested... Have to drop off more $$ this week so might have to:spy:
