2000 cold starts
Discussion in '1st Gen. Tacomas (1995-2004)' started by blake markham, Dec 6, 2007.
  1. Dec 6, 2007 at 11:34 AM
    blake markham
    blake markham [OP] New Member
    2000 4x4 reg cab
    Its hard to start the first then after that it start fine
  2. Dec 6, 2007 at 2:46 PM
    backwoodking
    backwoodking Well-Known Member
    Thousand Oaks/Southern CA
    3.4 V6 Deck Plate and Cut Turn-Down
    Deck Plate, Hitch, Cut Turn-Down Exhaust, Tint, Clear Corners, Shell, Full Size bed in the pickup, Hopefully More Soon
    How hard is the start? My 2000 takes a few cranks, like 5 or so before it gets kickin. in the cold. It seems normal to me and it has never stalled.
  3. Dec 6, 2007 at 3:09 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    how long has it been since you : 1- replaced spark plugs?
    2- replaced fuel filter and cleaned throttle body?
  4. Dec 6, 2007 at 4:01 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    How old is the battery? Starter? Look in to those things first. If the battery is over 4 years old then it's probably time to get a new one especially with winter knocking on the door.
  5. Dec 6, 2007 at 5:26 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    I got nothin' :confused:
  6. Dec 6, 2007 at 6:24 PM
    98yota
    98yota Mean Green Machine
    Marion, VA
    4WD Timberland Mica taco
    CAI, gutted cat, bed cover.
    mine does the same thing too, it takes about 4-5 times to crank b4 it starts, but i have the opposite problem. when mine gets hot and you cut it off and try to cut it back on between 10min to an hour later, it takes forever to start back up, i figured where the fuel filter sits right under the manifold and it vapor locks, but other than that idk
  7. Dec 7, 2007 at 1:01 AM
    blake markham
    2000 4x4 reg cab
    I have change the plugs and the fuel filter it help a few day but now it back to the same thing.
  8. Dec 7, 2007 at 3:19 PM
    concrete jedi
    Rochester N.Y
    Sounds like fuel system has a small leak.
  9. Dec 8, 2007 at 9:44 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    My 01 is the same way and has been that way since new,that is it turns over longer than I think it should.I also have two GM vehicles they start almost instantly.
  10. Dec 9, 2007 at 6:36 AM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    have the battery checked at napa of somewere like that
