2000 lbs In Bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrbadwrench, Mar 15, 2013.
  1. Mar 15, 2013 at 4:27 PM
    LordRingo
    LordRingo Member
    Kitchener, Ontario
    2013 TRD Access Cab Trail Teams Pro
    When I saw the title of this thread was 2000lbs in bed, I thought it was about my sex life.
  2. Mar 15, 2013 at 4:36 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    My 4x4 reg cab is 3110 lb . Guessing empty axle weight is 1620 lb + 2000 is 3620lb. So, if those were accurate , it would be overweight on the axle . Considering braking and accelerating, especially on a shorter wheelbase, you could add even more wight shifting.
  3. Mar 15, 2013 at 6:27 PM
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    that's fuck all
  4. Mar 15, 2013 at 6:39 PM
    majorhavok
    majorhavok Rabid Conservative
    Mike in Cali..
    Peoples Republic of Caulifournia
    '13 TRD Sport DoubleCab 4x4
    Ultragauge, ImMrYo mirror, Tailgate lock, Snugtop Rebel Shell.
    x4. I certainly don't want to hear nanny/pansy crap. Gotta watch out though, some of these puddin' brains still resent not being allowed on the safety patrol as a child and will report you to the police or toyota warranty as was already stated.
  5. Mar 15, 2013 at 6:40 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    It wasn't very bright , just sayin
  6. Mar 15, 2013 at 6:42 PM
    taco terror
    taco terror My ECT button stays clicked ;)
    Austen
    North Carolina
    Non-Turd Gen
    AR Baja wheels, 33 BFG ATs, 4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, Line-x
    Hahaha, wtf
  7. Mar 15, 2013 at 6:46 PM
    ARB1977
    ARB1977 You done messed up a-a-ron
    North Texas
    15 DCSB Prerunner 4.0L
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    I've got 1 qubic yard of garden topsoil to pick up tomorrow. Well see how my Deavers hold up.
  8. Mar 15, 2013 at 6:49 PM
    aidenhardcore
    aidenhardcore Well-Known Member
    miguel
    boston,ma
    2010 4 door black
    None yet but soon all black.
    Awesome!!!!!! Maybe alittle to much weight but I would have done the same thing. Its a truck. Get to work and use it how your suppose to. Some guys might think its very dangerous but if you go slow, I see no problem at all. If your gonna load your truck like that every single day then yes its bad but for every else in awhile, I see no harm done. Im glad your putting your truck to work like it should be!!!
  9. Mar 15, 2013 at 6:50 PM
    Tacoyota
    08 4wd
    I don't think any Tacoma model is rated at over 1400lb, maybe 1500lb. Hasn't been an issue for me though, hauling off yard debris, mostly leaves, I just do in 2 trips.
  10. Mar 15, 2013 at 6:52 PM
    RAT PRODUCTS
    RAT PRODUCTS RAT Products
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    I hauled 1500 lbs in my truck over 35 miles. Wasn't sketchy and braking was fine. I wouldn't do it often but if it needs to get done, I'd make a judgement call.
  11. Mar 15, 2013 at 6:56 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    You live in NoHo... you already share the road with much worse than an overloaded Tacoma.
  12. Mar 15, 2013 at 6:57 PM
    Tacoyota
    08 4wd
    Some rigs have the tow haul mode transmission button, it would be slick to have an option on our trucks with a load /no load switch. Perhaps upgraded parts for a 2k load and an airbag setup to take advantage of more heavy duty at those times.
  13. Mar 15, 2013 at 6:57 PM
    Mr. Pick
    Mr. Pick Well-Known Member
    Middle TN
    '12 AC, SR5, 2.7L, Auto
    Yep, I'd have made the trip, and done so safely, just as the OP did. I'd be more worried about the bed cracking than anything.
  14. Mar 15, 2013 at 7:02 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    nice OP! i have yet to make my truck come that close to the bump stops. all tho for big heavy stuff i just up it on our trailer.
    and THIS! I see soo many truck not getting used. and when asked why they got a truck they say.”just so i can say i have one, i hate the mpg, i hate the ride. only have it so i can say i have it.” and i respond with whyTF don’t you trade...
    If i did not need a truck and 4wd i would not have one.
  15. Mar 15, 2013 at 7:31 PM
    #35
    nathan3306
    nathan3306 Well-Known Member
    Nathan
    Charleston AFB, SC
    2012 SR5 DC 4X4
    I think he will be ok....
  16. Mar 15, 2013 at 7:45 PM
    #36
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    Wow! Guess ya got to do what ya got to do. That pic was crazy.
    Brett
  17. Mar 15, 2013 at 7:46 PM
    #37
    jrogers329
    jrogers329 Well-Known Member
    Huntsville, AL
    2011 Prerunner TRD DCLB-TRADED!
    Yeah but that commercial is BS. If you look, there is a power supply in the back of the Tundra, and cables running over the tailgate. Those dollys that the shuttle is resting on are powered by the box. There is NO WAY that a stock Tundra can tow almost 300K lbs. I drive an 18 wheeler, and my daycab really has to work hard when I am close to the legal limit of 80k lbs.
    OP...glad all went ok. Way to really use the truck
  18. Mar 15, 2013 at 9:05 PM
    #38
    fjrmurph
    fjrmurph Well-Known Member
    That was a hydraulic power pack for the steering axles on the trailer and i think on good level ground there is no reason a Tundra wouldn't tow that weight, i saw it on TV it has to be true !!!!!!
    Check it out
    http://www.youtube.com/watch?NR=1&feature=endscreen&v=kzfND5fcpB4
  19. Mar 15, 2013 at 9:09 PM
    #39
    fjrmurph
    The only thing i would have done different is take the bags off the pallet, you could have loaded them farther forward, get a little more weight on the front axle, share the load !!!!
  20. Mar 15, 2013 at 9:19 PM
    #40
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    canton Ga
    06 reg cab sr5
    General lee horn mod, Bilstein 5100's and maxtrac 4 inch lift spindles. omd spring rebuild w/ s10 springs kenwood h/u and cb, warn trans4mer brush guard level 8 tracker wheels and cooper s/t 33's
    The most I have hauled with my tacoma is 1300 lbs. Im sure the taco would still be better in an emergeny situation than the k5 blazer I had before the taco. And thats with the blazer.unloaded
