2000 PreRunner Fender Flare molding
Discussion in '1st Gen. Tacomas (1995-2004)' started by ddougee, Jun 17, 2022.
  1. Jun 17, 2022 at 11:54 AM
    ddougee
    ddougee [OP] Member
    2000 PreRunner
    I'm looking for options. Has anyone found a rubber trim molding that works well on the 1st gen. Tacoma fender flares? The ones that came on my Tacoma look like a door edge guard type molding but I just can find the right one to replace them all? Let me know what you have found that hold up well. Thanks....
  2. Jun 17, 2022 at 12:43 PM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
  3. Jun 17, 2022 at 2:16 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    These are easily available from Toyota still:
    https://parts.toyota.com/a/Toyota_2...-4WD/_65510_6725575/MOULDING/674460-7552.html
    Front Right: 53851-35061
    Front Left 53851-35061
    Rear Right: 61783-35071
    Reader Left: 61783-35091
    Search around for the best online pricing.
    You're going to need replacement clips if you remove the fenders. The old plastic breaks. They are a pain to get the old ones out.. Take your time. There are red and blue ones.. Someone had a link to some non-OEM clips- which are just fine. They can be a bit pricy for OEM ones by the time you add them all up.
    The new "pads", as toyota calls them, will have a small adhesive strip. So clean up the edge of the flare with alcohol to remove the old residue. I found that the new rubber is the correct length, so take care not to tension the rubber as you apply it.
  4. Jun 17, 2022 at 2:35 PM
    ddougee
    ddougee [OP] Member
    2000 PreRunner
    The parts you listed are for an entirely different type of fender flare. The factory flares that I have do not have any plastic clips. Just flange bolts around the wheel opening.
  5. Jun 17, 2022 at 2:48 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    nope- same flare- yours just happen to be paint matched**.
    A couple of screws on the bottom edges, and then clips up around the top.
    ** Unless the photo you posted is not from your truck. In which case, why would you do that?
    Or you could also put your vin in and or call a Toyota dealership if you don't like free internet help.
  6. Jun 17, 2022 at 3:15 PM
    ddougee
    ddougee [OP] Member
    2000 PreRunner
    It does look similar but I have no mounting holes for clips on my fenders or quarter panels. I have pulled the flares off to paint them so I can see there are no clips. I was hoping to buy a roll of molding rather than order all the 4 individual pieces that are pre-cut and sold by Toyota.
