2000 Tacoma Emergency Brake Light Problem, How can i fix it? PLEASE HELP
Discussion in 'Technical Chat' started by frankygomez01, Oct 7, 2010.
  1. Oct 7, 2010 at 8:56 PM
    frankygomez01
    frankygomez01 [OP] Rolling Low And Smashing Hard
    Franky
    Under A Roof
    2000 Tacoma Single Cab
    K&N Intake, Black 18" Kyowa racing rims, 6 inch drop kit
    So my Emergency Brake light keeps turning on while im driving and i cant figure out why. I changed the Brake switch but i still have the same problem and my brake fluid is fin as well. Any suggestions?
    Thanks
  2. Oct 7, 2010 at 9:03 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Did you change the switch on the parking brake? Or on the brake pedal? The two things that will turn the light on are the parking brake switch and the low brake fluid switch. Perhaps the float switch in the brake fluid reservoir is bad?
  3. Oct 7, 2010 at 9:07 PM
    frankygomez01
    Franky
    Under A Roof
    i changed the one on the parking break pedal and it didnt go out so idk what to do
  4. Oct 7, 2010 at 9:24 PM
    joes06tacoma
    Joe
    Central Coast, CA
    If it were me, I would look under the dash at the parking break switch and make sure it's actually getting pressed in. Then, pop the hood, disconnect the connector going to the brake fluid reservoir switch and see if the light goes out with the park break off. If not, try jumping the two terminals inside the harness connector at the reservoir switch. I am not sure if you are opening or closing the circuit when the brake fluid gets low.
    I am thinking you have a sticky float switch.
  5. Oct 7, 2010 at 10:33 PM
    frankygomez01
    Franky
    Under A Roof
    I fixed it right now, guess my dad didnt check my break fluid good and turned out it wasnt topped off, now that i topped it off it turned the light off.
    thanks anyways guys for the help
