2000 Tacoma will not start
Discussion in '1st Gen. Tacomas (1995-2004)' started by carl1524, Nov 4, 2011.
  1. Nov 4, 2011 at 6:11 AM
    carl1524
    carl1524 [OP] New Member
    North Carolina
    2000 Toyota Tacoma
    2000 Tacoma 4x4 3.4L V6
    Truck started, reached to put in gear, stalled. Started sounded like it was grinding, replace started. New starter will not turn motor. I can reverse the crank pulley with a socket and bar to a certain point and then it will stop. Try starting engine after and it wil turn over like it wants to start but hits a certain point and stops. At this point I can not rotate the engine forward with the socket and bar on the crank pulley but I can reverse it and it will do the same thing again. Starter engages but will not rotate engine beyond a certain point.
  2. Nov 4, 2011 at 7:08 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    is the motor locked?
  3. Nov 4, 2011 at 7:23 AM
    carl1524
    North Carolina
    2000 Toyota Tacoma
    I don't believe so. I can rotate the crank pulley back and forth one to one a quarter full turns. But both ways it hits a definite stopping point.
  4. Nov 4, 2011 at 8:03 AM
    XwesleysnipesX
    XwesleysnipesX Well-Known Member
    Eric
    Batesville, Indiana
    1996 2.4L 2x4 (sold). 2002 2.7L sr5 4x4 (sold)
    Maybe your starter is binding up with the flywheel Did the gears line up?
  5. Nov 4, 2011 at 11:18 AM
    carl1524
    North Carolina
    2000 Toyota Tacoma
    Yes, the gears lined up.
