2000 toyota tacoma
Discussion in '4 Cylinder' started by wellsfargo, Jun 26, 2011.
  1. wellsfargo
    wellsfargo [OP] Member
    2000 toyota tacoma 2.4 litre
    please give me clues should I replace my thermostat and temp switch if things show they are getting hot but everything looks normal under the hood???
  2. wellsfargo
    it showed yesterday tht it was hot going up a hill but goes up and down on the dash under the hood everything looks good should I just replace the thermostat and temp switch???
  3. wellsfargo
    water pump not leaking radiator full hoses look good clean air filterno leaks at all belt not slipping with a/c on going up a hill in 103 degrees temps outside ny truck almost got to the red but now just sorta goes up and down runs kool on flat levels do you think the temp switch and thermostat should be the problem????
