2000 tundra SR5 prerunner brake fault.
Discussion in '1st Gen. Tacomas (1995-2004)' started by hamish, Oct 21, 2010.
  1. Oct 21, 2010 at 7:30 AM
    hamish
    hamish [OP] New Member
    2000 tundra prerunner
    When I start up the vehicle the brake light comes on and stays on for 5 minutes ands then goes off. It repeats always. I removed the wire from the master cylinder and this stops the brake fault. I presume that the cylnder pistons leak. Is it worthwhile to rebuild or should I buy new replacement?
    When I bought the car used in 2001 the seller told me it was an SR5 and prerunner. When I look up the part it asks whether it is an SR5 or prerunner. I am confused about what I bought. Otherwise great vehicle.
    Thank you,
    Hamish J. Wilson
  2. Oct 21, 2010 at 7:36 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    Are you sure that is the problem? I would want to be sure before I started tearing into and rebuilding things. Are you sure it is not asking if it a 4x4 or prerunner?
  3. Oct 21, 2010 at 7:38 AM
    98tacoma27
    Ben
    Not Beech Creek
    Check the fluid level and the E-brake.
    Pre-runner = 2wd on a 4wd chasis/suspension. SR5 is just a bling package (chrome this and that, maybe different seats).
  4. Oct 21, 2010 at 1:16 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    Also...no such thing as a Tundra Prerunner.
  5. Oct 21, 2010 at 2:03 PM
    hamish
    Parts suppliers list tundra prerunner. I am confused!
    Thank you,
    Hamish
    :confused:
  6. Oct 21, 2010 at 2:09 PM
    RattleTractor
    Harry
    VT
    '04 Unicorn Tacoma
    Pretty sure they only had 2wd and 4wd models...no "prerunners (2wd on 4wd frame)
