2001 keyless remote door lock install
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomabg, Jun 15, 2016.
  1. Jun 15, 2016 at 9:43 AM
    Tacomabg
    Tacomabg [OP] Member
    I just purchased a double cab Tacoma 2001 and it does not have remote door locks. Can i buy a kit to install this option? If so can somebody point me in the right direction for this item
    I have looked for a kit and did not find a kit just for this truck ... just a universal and i would rather not buy that
    THANKS.
    Brad
  2. Jun 15, 2016 at 12:29 PM
    1988Mercedes
    1988Mercedes Well-Known Member
    CHARLES
    ARKANSAS
    2020 AG PRO MT
    Real simple if you have electric lock already. Most all kits will work
  3. Jun 15, 2016 at 5:05 PM
    Tacomabg
    It has the power locks just not remote operated .. Does anybody make kit just for 2001 tacoma that would a plug and play install??
  4. Jun 16, 2016 at 2:04 AM
    1988Mercedes
    CHARLES
    ARKANSAS
    2020 AG PRO MT
    Your not going to find that. I did a minimal install on mine for the same reason. I wanted remote locks but no alarm. I just wired in a $75 alarm system and left the siren off.
  5. Jun 16, 2016 at 10:04 AM
    STOCKTRD
    STOCKTRD Well-Known Member
    In Traffic
    CustomTacos Mafia!
    Nachos, Lemon Heads, My Truck Is Stock!
  6. Jun 16, 2016 at 3:30 PM
    Tacomabg
  7. Jun 17, 2016 at 7:30 PM
    Tacomabg
    installed today with very little problem. Just used the negative trigger wires unlock and lock to the gray and purple wire on truck and worked perfect. The only problem was trying to get horn to beep when locking and unlocking. Couldnt get that to work. Just going to add a positive feed horn to positive output on unit
    RedManRocket and DustStorm4x4 like this.
  8. Oct 3, 2018 at 9:46 AM
    Mainetac
    Mainetac New Member
    2001 Toyota Tacoma 6 cylinder
    Very easy to install Docooler Car Remote Central Lock Locking Keyless Entry System purchased on Amazon. (KMOON)
    2001-2003 Tacoma
    *Take off panel under dash, 4 bolts, 1 Philips screw, don't need to remove hood latch cable. set out of the way.
    *Find bolt or screw on metal bracket under dash, connect Black AND Yellow and Yellow/Black to ground.( directions with remote kit in B drawling states 'Positive Trigger-- Yellow and Yellow/ Black STILL GO TO GROUND as diagram shows- some have stated that this is wrong).
    *Tap white on key less wire harness to gray wire that comes from wire junction under dash left of steering column.
    *Tap White/Black from key less harness to Purple wire that comes from wire junction under dash left of steering column.
    *Find thicker White/Red wire near steering column going into plug junction. This is always on 12v +, connect red wire to this.
    Don't have to do anything else to have remote lock and unlock doors. That easy.
  9. Dec 23, 2018 at 9:55 PM
    wfaraoni
    wfaraoni Member
    2019 tacoma sr
    I wonder if these wire colors are the same for gen 3 models
  10. Dec 23, 2018 at 10:09 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Most likely not, but I'm sure you can find a schematic on Google.
