2001 Taco Drain Bolt
Discussion in '1st Gen. Tacomas (1995-2004)' started by cadmonkey, Nov 24, 2007.
  1. Nov 24, 2007 at 10:29 AM
    cadmonkey
    cadmonkey [OP] New Member
    2001 Tacoma Reg Cab 4WD 2.7L 4CYL
    Hello,
    I have just purchased a 2001 Tacoma 2.7L 4WD.
    I have changed the oil and discovered something I have'nt seen before.
    This truck has an oil pan drain bolt that looks like it is a "zirc" fitting. It has a rubber cap that when removed exposes a core that looks like a zirc fitting! A brass ball is somehow depressed and drains. Looks as if a "spigot" can be inserted to drain the oil without removing the bolt. Anybody heard of these? Danger of leakage?
  2. Nov 24, 2007 at 1:09 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
  3. Nov 25, 2007 at 12:04 PM
    cadmonkey
    No, this is not any kind of a "petcock" or ball valve. It looks like a bolt, but has a removable center rubber cap and when removed, you can see a spring loaded ball, remindeds me of a grease fitting. I think I will take a picture of it and post it.
    Thanks though......
