2001 tacoma 2.5 inch lift and tire question
Discussion in '1st Gen. Tacomas (1995-2004)' started by ryquic772, Jun 15, 2013.
  1. Jun 15, 2013 at 10:30 PM
    ryquic772
    ryquic772 [OP] New Member
    01 tacoma
    i have a 2001 tacoma not a daily driver want to do a little cheap 2.5 inch lift on it with some new tires and rims..... the truck will be in mud alot and some trails and driven around town once in a whiile.....
    heres the question what is the biggest tire i can run with the 2.5 inch lift?
    is there a certain back spacing on rim or spacers to help fit bigger tires or certain size rim i should get like a 15 inch vs 17inch?
    i would like to get close to a 33x12.5 might not be possible but just giving an idea of what i thinking and i dont mind at all cutting or bending panels away to fit the tires or even a little rub since it just a play truck....just seeing if i could get some help getting a little parts list together since idk much about it thanks alot guys!
  2. Jun 15, 2013 at 10:37 PM
    661prerunner
    661prerunner Well-Known Member
    Santa Clarita
    01 prerunner
    FabTech C/Os, Solo tubular UCAs (on order)Solo spindles(not installed) Glassworks front and rear, made by me Rocksliders, Premier Navi,
    If you dont mind trimming you will should be fine. some do 35s on 3inches of lift
  3. Jun 16, 2013 at 11:04 AM
    ryquic772
    01 tacoma
    To fit the 33x12.5 any idea what wheel spacing or rim off set u would need ?
    Thanks for the reply
  4. Jun 16, 2013 at 12:01 PM
    661prerunner
    Santa Clarita
    01 prerunner
    I dont remember what I have But I want to say 4.5.
    I have Fabtech C/Os set at like 2.75( dont quite remember I just wanted a lifted truck 5yrs ago) now Ive been fixing all my mistakes. and only rub frame at ride height.
    I have since bought UCAs and Spindles and will trim after I install them. I havent wanted to trim due to not having my suspension done right to start
  5. Jun 16, 2013 at 1:33 PM
    ryquic772
    01 tacoma
  6. Jun 16, 2013 at 2:37 PM
    661prerunner
    Santa Clarita
    01 prerunner
    I run rear blocks now and I hate them. Stiff as all hell and are not good for already weak leaf springs. Get full leaf pack or aal
    As for the front since you know your off roading I'd get something you can rebuild saves money in the end
  7. Jun 16, 2013 at 2:43 PM
    661prerunner
    Santa Clarita
    01 prerunner
  8. Jun 16, 2013 at 6:40 PM
    ryquic772
    01 tacoma
    thanks for all your help
  9. Jun 16, 2013 at 11:23 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    For 33x12.5s you'll want 3.75 or less back spacing. You'll also have to cut the pinch weld and probably the lower front fender a bit.
    F0r 35s will have to trim whole fender and tub fire wall.
  10. Jun 16, 2013 at 11:26 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    I had 2.4 on mine with 33 12.50s with 4.5 backspacing. TRim the plastic, and beat the hell out of the pinch weld. Still gonna rub a little bit though. A lot if you're turning and hit a bump fast.
  11. Jun 17, 2013 at 6:52 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    33x12.5r15s?? Or 285/75r16s??
    Cause with 33x12.5r15 you rub the UCA with 4.5" BS.
