2001 tacoma suspension
Discussion in '1st Gen. Tacomas (1995-2004)' started by anvilhead, Apr 13, 2007.
  1. Apr 13, 2007 at 12:19 PM
    anvilhead
    anvilhead [OP] Active Member
    OK I think my 2001 has a front lift kit over the coil springs. Does anyone have any pictures of stock front suspension? I want to remove the lift if that is what I am looking at. Can I just remove the shocks and remove teh block from the front end over teh coil spring? ANyone KNow? I just need a stock truck... not lifted any, unfortunately I drive much more on the highway than i do offroad and when i do drive offroad its usually at teh beach. and when im at teh beach I am usually fishing more than I am riding and when i do ride on teh beach i ride slow. so anyone with any information I would appreciate it.
  2. Apr 16, 2007 at 5:42 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    does it look like a inch and a half peice of metal or rubber if it is lifted you should be able to jut take out the spacer and you are back to stock
  3. Apr 17, 2007 at 6:46 AM
    anvilhead
    Yeah It looks like a Metal spacer. It is between the spring and the spring housing. can I take it out withoug compressing the spring? How does this all fit together?
    Doug
  4. Apr 17, 2007 at 9:52 AM
    2003greenbean
    socaste,sc
    03 trd
  5. Apr 17, 2007 at 11:06 AM
    anvilhead
    I appreciate your help. will let you know how it turns out.
  6. May 10, 2007 at 9:09 PM
    99taco3150
    99taco3150 Member
    are you going to sell or give away that spacer when you take it out? If you are, i would be interested.
  7. May 13, 2007 at 8:49 AM
    anvilhead
    I need a set of original strut mounts. If someone has some let me know.
  8. May 16, 2007 at 12:40 PM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Ebay (Tokico) Are you looking at TRD or non-TRD?
  9. May 16, 2007 at 12:56 PM
    anvilhead
    Bought a set of Strutt Mounts and finished installing them yesterday. SO I guess I dont need anything now. The freaking mounts were a little over 50 bucks a piece. I will sell the spacers I had in it. drop me a line if anyone is interested.
  10. May 16, 2007 at 3:11 PM
    99taco3150
    99taco3150 Member
    what size spacers are they?
  11. Sep 29, 2007 at 9:36 PM
    scard
    scard Active Member
    El Centro, CA
    2001 Toyota Tacoma PreRunner Total Chaos UCA's with Donahue Racing Coilovers
    Magnaflow Exhaust, Total Chaos Upper Control Arms with Donahue Racing Coilovers, Bilstien Shocks in the rear.
    I have the upper control arms with the spacers and the stock coilovers and the are already in a box. I have the Total Chaos kit and the have the stock parts. Call me @ 760-562-0005 my name is Alex
