2001 Tacoma Viper 5704 install help
Discussion in 'Audio & Video' started by LowLyfe, Nov 8, 2012.
  1. Nov 8, 2012 at 9:42 PM
    LowLyfe
    LowLyfe [OP] New Member
    Utah
    01 Double Cab Limited 4x4
    K&N Air Filter
    Hey everyone, ive been lurking the site for awhile...but havent posted much here. But i need some information on the install of the viper 5704 alarm...
    Heres the wires i have
    H1/1 - 12vDC constant ----------White/red wire at Ignition
    H1/2 - Chassis Ground -----------Grounded
    H1/3 - Siren Output -------------- Red wire from siren speaker(and also pezo postive wire spliced in)
    H1/4 - Parking light Isolation -----Dont Need?
    H1/5 - Parking Light Output - Green (+) back of fuse box
    H1/6 - Ground when armed - Dont Need? If i had a tilt sensor i would hook here
    H2/2 - Neutral Saftey ------Grounded
    H2/6 - Door Trigger - I have a diagram that i must wire in 4 diodes to all 4 door pin trigger wires.
    H2/8 - Horn Honk ----------- Green/Red Steering Column
    H2/16 - Brake Shutdown ---- Green/White Brake Pedal
    H2/17 - Hood Pin Input ------- To hoodpin (if i use)
    H2/19 - Instant Trigger Input ------- Blue wire from backup battery (520t)
    H2/23 - Tachometer Input----- Light Green/Black (at igniter on pass fender)
    H3/1 - Ignition Input/output ----- Black/Red Ignition Switch
    H3/2 - Fused Ign. 2 ---------------Black/Yellow IS
    H3/3 - Accessory Out -------------Blue/Red IS
    H3/4 - Starter Out ----------------Black (car side)
    H3/5 - Starter In ------------------Black (key side)
    H3/6 - Fused Ignition 1 Input ----- ????
    So, if i didnt list it im pretty sure i dont need it? Also, does any of these require relays?
    And i Had a question about the Gray wire +12v output from the backup battery..does this actually goto H1/1 and then the Red wire on my backup battery goes to the White/Red wire at ignition?
    The door lock harness im good with, and the 2 sensors (glass break, shock) are just plug in play.
    Thanks for anyones help in advance, i greatly appreciate it.
    Dee
  2. Nov 25, 2012 at 12:31 AM
    Riverdog
    Riverdog Well-Known Member
    Collin
    Portland, OR
    '05 Double Cab PreRunner
    Hey Dee,
    I don't know if you've figured everything out yet or not, but I would post this exact thing on www.the12volt.com if you haven't solved anything yet. You'll want to post here. Its their car alarm/remote start forum.
    I have a 2005 Tacoma and just posted some questions on the12volt about installing a 5704 and got clear answers right away. Good luck and let me know how it goes!
  3. Dec 1, 2012 at 4:53 PM
    LowLyfe
    Utah
    K&N Air Filter
    Yea i posted there after. Heres the correct Information in case anyone else needs help. This is for the viper 5704 Remote start harness only. If you need help with the actual alarm harness all the info is at 12volt.com
    H3/1 (+) igntion 1 input/output ====== black/red
    H3/2 (+) fused 30a Ignition 2/ ====== White
    H3/3 (+) accessory output ====== blue/red
    H3/4 (+) starter output car side ====== black wire car side
    H3/5 (+) starter input key side ====== black wire key side
    H3/6 (+) fused 30a Igntion 1 input ====== White/Red
    H3/7 (+) igntion 2 / flex relay output ====== Black/Yellow
    H3/8 (+) flex relay input 87a key side ====== Not Used
    H3/9 (+) fused 30a accessory/starter input ====== White
    H3/10 no connection ====== no connection
