2001 trd elocker rear axle shafts
Discussion in '1st Gen. Tacomas (1995-2004)' started by Heartland Hunter, Apr 25, 2022.
  1. Apr 25, 2022 at 10:00 AM
    Heartland Hunter
    Heartland Hunter [OP] Well-Known Member
    Danny
    2001 Tacoma
    My 2001 trd with abs i believe has a bent driver side rear axle shaft flange that is bent im getting a wobble out of the tire not vibrations I have taken the tire and drum off and can see the axle wobbling. I replaced the axle bearing and seals that didnt fix the problem.
    So im searching for a replacement axle. i have found many 4runner abs axles but not sure if they will work.
    Also was looking at a yukon YA T35350 per marlins site you have to replace the bearing case? but ive read on other sites you just have to install a 99 style bearing for the yukon?
    Has anyone gone through this and can give me some advice?
  2. Apr 25, 2022 at 10:34 AM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    You can run a non elocker rear axle as well. It's all the same.
  3. Apr 25, 2022 at 11:17 AM
    Heartland Hunter
    Danny
    2001 Tacoma
    @Nano909
    you think is safe to assume this axle shaft would work on my 2001 elocker axle? I would put my backing plate on it
  4. Apr 25, 2022 at 11:33 AM
    Heartland Hunter
    Danny
    2001 Tacoma
    I know its got to be a ABS axle
