2002 3.4 oil leak
Discussion in 'Technical Chat' started by jp59inh, May 13, 2018.
  1. May 13, 2018 at 2:43 PM
    jp59inh
    jp59inh [OP] Well-Known Member
    02 Tacoma Extra cab 4x4
    None yet
    ok guys I recently aquired an 02 ex-cab TRD 4x4 and it has an oil leak. I am just starting to clean the underneath and engine bay so I can locate the leak.
    My question is are there any “ comon” leaks that occur on these truck that I should look at first ?
    Thanks in advance for any pointers !
  2. May 13, 2018 at 2:50 PM
    Bishop84
    Bishop84 Well-Known Member
    My first concern with any oil leak is the oil pressure switch, if it blows it lets out the entire sump in seconds, pay close attention to it.
    Most commonly I've found is valve cover gaskets, crank shaft and cam seals (behind timing cover) and oil pressure switches.
  3. May 13, 2018 at 2:52 PM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Valve cover gaskets and cam seals. Like mentioned keep an eye on the pressure switch.
  4. May 13, 2018 at 3:25 PM
    jp59inh
    None yet
    Where is the pressure switch located on this thing ? Guess I should go get myself a good manual.
  5. May 13, 2018 at 8:47 PM
    jp59inh
    None yet
    Pretty sure its the driver side valve cover. Cleaned it and gunna drive it tomororw to work and then check it again.
