2002 Tacoma Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by BlackBirtha, May 4, 2015.
  1. May 4, 2015 at 12:31 AM
    BlackBirtha
    BlackBirtha [OP] Well-Known Member
    2002 Tacoma Double cab
    Thanks for checkin out my build thread
    Front:
    Camburg Race LT kit
    King 2.5 8" coilovers
    Fox Hydro bumps
    Camburg Limit straps
    Camburg 2.0 hubs
    Wilwood 4 piston calipers
    Rear
    Deaver F67 Sprung Under
    Chromoly Currie Axles
    4.56 Richmond Gears
    Wilwood 4 Piston Caliper
    Total Chaos 12" Shackles
    Trail Gear Frame box
    King 2.5 18" Triple Bypass
    Ford 9" trussed 4.56 Gears
    Miscellaneous
    Method Double standards
    General grabbers black labels
    TRD supercharger
    Glasswork unlimited Front and rear fenders
    Custom Bedcage by Desert Dream Motorsports
    Pioneer App radio
    Kicker 12" sub
    Momo Steering wheel
    Custom Front bumper and Skid plate
    Trd Stainless Headers
    Rigid LED bar
    When I bought it already had a Camburg race kit
    How it sat when I got it
    My old Ranger
    Drove down to SD to pick up a Ford 9"
    Swapped in some 4.56 gears
    Started tearing it down to start the rear
    All finished up, only ran into a few small problems. Pulls about 18" in the rear
  2. May 4, 2015 at 7:10 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Very Nice! How's it ride?
  3. May 6, 2015 at 10:54 AM
    BlackBirtha
    Rides pretty stiff in the rear but its nowhere close to breaking in, like 200 miles tops on the rear right now, so im sure its going to loosen up. Overall the truck handles good on road and even better off road
    otis24 likes this.
  4. May 23, 2015 at 6:39 AM
    Twitch.
    Twitch. Well-Known Member
    holy hell batman!!! very nice build
  5. Jun 27, 2015 at 2:05 PM
    Large
    Large Red
    This truck isn't getting the attention it deserves. Very clean and simple, I love that bed cage.
  6. Jul 1, 2015 at 11:25 PM
    BlackBirtha
    Thanks dude, ya I call it project nightmare lol but its worth every penny
  7. Oct 14, 2015 at 5:19 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Sub' to see this on a computer instead of my phone :D
    Edit: Very Nice! I like what you did with the front skid. :thumbsup:
  8. Nov 16, 2015 at 1:46 PM
    Tanner ORear
    Tanner ORear New Member
    Tanner
    Tennessee
    02 4x4 SR5
    3inch suspension lift and 3 inch body lift on 35in nittos
    you wouldnt happen to know where that roof rack came from would you?
  9. Nov 24, 2015 at 5:20 PM
    TuckGraham
    TuckGraham Keep it straight
    Tg
    Montana
    What roof rack is that?
  10. Nov 25, 2015 at 4:17 PM
    BlackBirtha
    Factory roof rack
  11. Nov 25, 2015 at 6:31 PM
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    hey man, could you pots more pictures of your secondary hoops? dont feel like spending 400 on ones from tc or camburg. trying to get ideas on how to do mine
  12. Nov 25, 2015 at 6:39 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Bad ass truck man.
  13. Nov 28, 2015 at 11:16 PM
    BlackBirtha
    Your talking about shock hoops right? Ill take some tomorrow and DM them to you on Instagram
  14. Nov 29, 2015 at 9:04 AM
    FlapJack935
    Jack
    Abq New Mexico
    yea up in the front , sounds good man thanks
  15. Dec 6, 2015 at 7:33 AM
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    How did those rear discs end up for you and did you mod anything to compensate the brake system for them?
  16. Dec 11, 2015 at 12:35 AM
    BlackBirtha
    They turned out good, never ended up using the smaller parking brake caliper. All i ran was a wilwood proportioning valve up at the master cylinder to adjust my brake bias.
    1stgenyota2014 likes this.
  17. Dec 11, 2015 at 12:19 PM
    j0shu4
    I'm curious because I have a t100 axle and am doing the tundra front brake conversion. I want to put my oem rotors and calipers on the rear t100 axle. Pretty sure all I would need would be brackets. What do you think?
  18. Dec 14, 2015 at 9:38 PM
    BlackBirtha
    I dont see why not as long as they are the same bolt pattern and most likely you are going to have to make brackets to get the calipers to work
  19. Dec 15, 2015 at 8:33 AM
    j0shu4
    Yeah, same bolt pattern. I might try it. I'm not sure yet but seriously considering it. Otherwise I buy new drums and pads for the t100 axle. Figured I'd do the disc swap and just buy brackets that convert a regular tacoma to disc in the rear. Some guys say not to run rear discs because of the extra fluid and pressure. That you'd have to get a bigger booster. So I saw yours and was curious. Yeah, I already have the wilwood prop. valve.
  20. Dec 17, 2015 at 9:47 PM
    BlackBirtha
    Ya the proportioning valve helps, but people are right about having to get a bigger brake booster, I still have the stock on and its a little sketchy but besides that they work great.
    94jdmeg6civic likes this.
