2002 Tacoma. Monroe Quick Strut Part #
Discussion in '1st Gen. Tacomas (1995-2004)' started by wckalijkd, Aug 27, 2018.
  1. Aug 27, 2018 at 7:17 PM
    wckalijkd
    wckalijkd [OP] Member
    2002 PreRunner V6 4dr Double Cab RWD
    Greetings. My first post here.
    I'm the original owner of a 2002 Tacoma, 4dr, V6 PreRunner. I finally broke the 100K mile mark few weeks ago.
    My struts/shocks are blown and needs to be replaced.
    For the fronts struts I am leaning towards the Monroe Quick Struts.
    I am confused on the correct Part #. Monroe's website provides Part #71351R and 71351L.
    All the online auto parts stores provide Part # 71352R and 71352L for my 2002 Tacoma.
    Can someone point me in the right direction?
    homegrown_xt likes this.
  2. Aug 27, 2018 at 11:44 PM
    02hilux
    Planet: EARTH
    L for left (driver) and R for right (passenger)
  3. Aug 27, 2018 at 11:50 PM
    wckalijkd
    351
    Or
    352
  4. Aug 28, 2018 at 12:01 AM
    02hilux
    Planet: EARTH
  5. Aug 28, 2018 at 12:03 AM
    wckalijkd
    Thx. Monroe website still shows 351.
    Will order tomorrow.
  6. Aug 28, 2018 at 12:07 AM
    02hilux
    Planet: EARTH
  7. Aug 28, 2018 at 7:51 PM
    01ColoTaco
    01ColoTaco Member
    Elizabeth, Co.
    01 TRD SR5 Xcab 3.4. Auto 4x4
    Stock
    Please post how you like them. I'm in need of a replacements too. I'm working through my suspension and want to keep stock. Thx.
  8. Aug 30, 2018 at 12:04 PM
    wckalijkd
    Ordered from Amazon. Got a reply from Monroe stating the 352s have the Wrong spring rate for the Double Cab. Monroe does NOT make a Quick Strut assembly for the Double Cabs at this time. Just cancelled my order from Amazon. Suppose to be delivered sometime today. Will get Bilsteins 4600s for front and rear.
    Is there a specific part # for the Bilsteins?
    Egbert45 likes this.
  9. Aug 30, 2018 at 7:35 PM
    01ColoTaco
    01ColoTaco Member
    Elizabeth, Co.
    Stock
    Does anyone know if these monroes are replacement for xcab TRD? I don't know if springs/shocks are different than non TRD models. Couldn't find anything on Monroe's website.
  10. Aug 30, 2018 at 7:55 PM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    I just went to the Monroe site, have JUST bought front Quick Struts and rear shocks via Amazon, all Monroe PN, listed for double cab, and Prerunner.
    http://www.monroe.com/en-US/e-catalog
    I didn't find anything on Google about them not being available for double cabs.
  11. Aug 30, 2018 at 8:08 PM
    Oldie2007
    Kurt
    Lockhart, TX
    Searching this site, I don't see that negative either. I bought them because I just want OEM ride (not Chris Craft!), and did not want to do the spring compression of ride change. I am just holding out for cooler weather! As far as I can see, you should be fine with the Monroe. Anyone knows different, please advise - I can still return mine! But don't see why.
  12. Aug 31, 2018 at 8:06 PM
    wckalijkd
    This is the search criteria I used at Monroe's website: 2002, Toyota, Tacoma, RWD, PreRunner, Crew Cab.
    Gives me part # 71351.
    Click VIEW DETAILS / TECH TALK.
    Some guy named Jake posted a question back on 10/31/2017.
    Following is the question and answer:
    98 Toyota tacoma, SR5, 4WD, extended cab.
    Please clairify which strut assemblies for my truck have the OE Spectrum struts. Based on the website specs the 71351 and 71352 are the OE Spectrum struts. I believe the 171352L and 171352R are the quick-sturt assmeblies with the OE Spectrum struts included. However the website specs have the 171351L and 171352R matching dimensionally and part number (P01101) with the Econo-Matic assemblies 181352L / 181352R. I believe the dimensions and part number in the tech specs are incorrect and should match the 71351/71352 with P01612. Or maybe it's all wrong. I'm confused....
    Can you confirm the 171352L / 171352R assemblies use the OE Spectrum Struts 71351 / 71352?
    I have the OE Spectrum shocks on the back and would like to replace the front struts with the same.
    Thanks,
    Jake
    Replies
    • [​IMG]
      Tenneco Tech Rep Jack M 305 days ago
      The 71351 is for the Double Cab Tacomas, if it is not a Double Cab it would use strut 71352. The Quick Strut is for the non Double Cab models and is part number 171352L and 171352R.
  13. Aug 31, 2018 at 8:13 PM
    wckalijkd
    This is where the confusion begins for me. Partsgeek, ebay, and other online vendors give me Part # 71352 (R&L).
    Amazon says 71352 will NOT fit my 2002 Crew Cab. Amazon has been known NOT to be 100% accurate.
    Based on the general consensus I went ahead and ordered the 71352s (R&L) and also posted a question if this will fit my 2002 Crew Cab or not. I got a response from Monroe Mfg.
    https://www.amazon.com/conversation...103337b/ref=pe_2567880_229859470_hdl_msg_notf
    ME: Will this fit a 2002 tacoma prerunner, v6, 4dr double cab, rwd?
    MONROE:
    Monroe C., MANUFACTURER answered • 2 days
    Hello, This is not applicable for the double cab 4 door application. It will install, but does not have the correct spring rate to accommodate for the heavier four door cab.
    ME: So I need the 352??
    MONROE: No, sadly Monroe does not manufacture or offer a complete strut assembly for this vehicle application.
  14. Aug 31, 2018 at 8:18 PM
    wckalijkd
    This is the strut / shock set I ordered from a local Off Road Auto Parts store. I ended up paying $400 for my set. Parts guy said any problems bring it back for exchange or full refund. Only reason why I didnt order from Amazon.
    Same part # as the set from Amazon.
    2 - Bilstein # 24-022842 Front Shocks
    1 - Bilstein # 24-184960 Left Rear Shocks
    1 - Bilstein # 24-184977 Right Rear Shocks
    https://www.amazon.com/BILSTEIN-SHO...UTF8&qid=1535743567&sr=8-2&keywords=24-022842
  15. Aug 31, 2018 at 9:06 PM
    Oldie2007
    Kurt
    Lockhart, TX
  16. Aug 31, 2018 at 9:10 PM
    Oldie2007
    Kurt
    Lockhart, TX
    And I missed my last sentence - Yours is 2002, Mine is 2007 - in between I don't know who is saying what. So, grain of salt to finish our research on any project!
  17. Sep 1, 2018 at 11:18 AM
    perniva1978
    perniva1978 Active Member
    Fort Worth TX
    04 PreRunner V6 Double Cab
    Bridgetone Dueler Alenza
    I had my local mechanic install the Gabriel Ultra ReadyMount in the front. They are amazing. These trucks are front heavy and these Gabriels have held up very well even two years later the ride is still very sturdy.
  18. Sep 5, 2018 at 7:38 AM
    wckalijkd
    Took 3 hrs to get all 4 shocks installed. My curb height went up 2 inches. Don't know if my truck slowly sagged over the years or the Bilsteins gave my truck an unwanted lift. Anyways the Bilsteins handle great.
    Oldie2007 likes this.
  19. Sep 5, 2018 at 10:21 AM
    perniva1978
    Fort Worth TX
    Did you keep the factory coils?
  20. Sep 5, 2018 at 10:23 AM
    wckalijkd
    Yes, I reused the OEM coil springs.
    Only replaced front struts and rear shocks.
