2002 Tacoma O2 Sensor
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tomato1981, Nov 12, 2017.
  1. Nov 12, 2017 at 7:10 AM
    Tomato1981
    Tomato1981 [OP] Well-Known Member
  2. Nov 12, 2017 at 8:34 AM
    Slickster
    Slickster greentaco
    2002 pre
    what engine do you have? sr5? 2vz?3vz?
    if it is a 3vz there are 2 sensors and looks like you might have replaced the wrong sensor with the wrong part number.
    on this engines there is one sensor right by the exhaust maniful and then there is another sensor down by the passenger door with is the one in that needs to be checked or replace.
    part number is
    Denso 234-4189 Oxygen Sensor
  3. Nov 12, 2017 at 8:40 AM
    Tomato1981
    I have the 3.4L V6. Wrong part?
  4. Nov 12, 2017 at 9:45 AM
    Slickster
    Slickster greentaco
    2002 pre
    yes different part
  5. Nov 13, 2017 at 4:52 PM
    ScrapmanIndustries
    ScrapmanIndustries Well-Known Member
    98 reg. cab tacoma, 17 access cab tacoma
    I too may be in need of a sensor. its a 98 2.7 regular cab. the nuts rusted completely off. needless to say its gonna be a bitch to change. did you also have that problem?
  6. Nov 15, 2017 at 11:49 AM
    Tomato1981
    The hardest part was unlocking the electrical harness kit
