2002 Tacoma Prerunner ex cab TRD Locking Rear Differential
Discussion in '1st Gen. Tacomas (1995-2004)' started by masonrules, Jul 10, 2020.
  1. Jul 10, 2020 at 2:31 PM
    masonrules
    masonrules [OP] Member
    DESERT HOT SPRINGS, CA 92240
    2002 Toyata Tacoma Extra cab Prerunner TRD
    FRONT LIFT AND HELLWIG SPRINGS FOR REAR
    Hello Everyone!
    I am going to need my locking rear differential overhauled or replaced. I can't afford to do it right now and I don't drive the truck much. The differential is NOT leaking but when I had it changed, my mechanic showed me bits of metal shrapnel in the fluid. Any suggestions for not making it worse? ie, Should I change the fluid and keep plenty of fluid in it? All feedback is more than welcome!
    Mason
  2. Jul 11, 2020 at 3:05 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Simple Don`t drive it .
    Are you talking just tiny pieces or good size chunks ??
    Unless you plan to just replace the differential when it fails completely.
    The bad part it only takes a small broken part to lock up the differential
  3. Jul 11, 2020 at 3:12 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    What’s the gear ratio? I’ve got a 4.10 rear third member for sale here in the Bay Area.
