2002 Tacoma SAS
Discussion in 'Solid Axle Suspension' started by Yia, Jan 8, 2014.
  1. Jan 8, 2014 at 4:41 PM
    Yia
    Yia [OP] Member
    Bakersfield
    02 Tacoma
    Bent the frame on my 2002 Toyota Tacoma so I decided to do a SAS. Found a Frame for $100 from a local guy that was rust free and straight.
    Before:
    Specs:
    2002 Tacoma Reg Cab 2.7L 5 speed
    Front suspension-
    TG 3in SAS Kit
    TG driver drop axle housing with Toyota elocker 5.29
    Rear suspension-
    Allpro Offroad 5in Tacoma lift
    TG rear axle housing with Toyota e locker 5.29
    Drivetrain-
    TG 4.7 Tacoma Dual Case
    In progress:
    Front suspension-
    4WheelUnderground front 3 link kit with 14in Radflo Shocks
    Passenger Drop 66 wms-wms Diamond Axle housing with Toyota elocker 5.29
    Rear suspension-
    Chevy 63 leaf spring
    2005 Toyota Tacoma Rear elocker Axle 5.29
    Drivetrain-
    Toyota dual gear driven transfer case with TG adapters
    4WheelUnderGround Front 3 Link Kit
    Mocking the steering box and lower links
  2. Jan 17, 2014 at 2:24 PM
    Yia
    Yia [OP] Member
    Bakersfield
    02 Tacoma
    Dropped the motor and transmission and welded some motor mounts.
  3. Jan 17, 2014 at 3:28 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Nice looking truck!! That 4WU kit looks beautiful, as always. Should be pretty bad ass after it's all done.
    Got any more pictures from the initial swap?
  4. Jan 17, 2014 at 3:29 PM
    Large
    Large Red
    Damn goood work.
  5. Jan 17, 2014 at 3:34 PM
    foxhead
    foxhead Well-Known Member
    Andrew
    Colorado Springs, CO
    2016 DC Tundra
    Good looking shit
  6. Jan 17, 2014 at 3:59 PM
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Subbed!
  7. Jan 17, 2014 at 9:19 PM
    Yia
    Yia [OP] Member
    Bakersfield
    02 Tacoma
    Thanks.
    The 4WU 3 link design looks amazing.
    Here are some pictures from the TG kit.
    When it was first completed. Sitting on 33 BFG KM2.
    With the new wheels and 35.
  8. Jan 17, 2014 at 9:23 PM
    Yia
    Yia [OP] Member
    Bakersfield
    02 Tacoma
    Yes its the Elite bumpers.
  9. Jan 20, 2014 at 9:56 AM
    Yia
    Yia [OP] Member
    Bakersfield
    02 Tacoma
    4.7 Gears
    Installed with TG twin shifter and adapter plate
  10. Jan 24, 2014 at 9:50 AM
    Yia
    Yia [OP] Member
    Bakersfield
    02 Tacoma
    Mounted the motor on the frame and started mocking the front 3 link kit.
    Panhard Frame Mount
    Driver side bump stop
    Passenger side bump stop
    Going to install the cab, mock the coilovers and cycle the suspension checking for clearance next.
  11. Jan 24, 2014 at 1:57 PM
    99nmtaco
    99nmtaco Well-Known Member
    Patrick
    NM / VA
    2001 4 Runner
    ADS racing shocks ext travel front, ADS FJC piggyback shocks rear, Addicted Offroad front plate bumper, 4xinnovations rock sliders and rear plate bumper, SCS Stealth 6s
    Wow! That 4WU kit looks awesome! Love your truck by the way cant wait to see the rest of the 3 link done! Did you just keep the trail gear frame plates and steering box mount to use with the 4WU kit?
  12. Jan 24, 2014 at 2:05 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Looking good Subbed! :popcorn:
  13. Jan 27, 2014 at 8:21 AM
    Yia
    Yia [OP] Member
    Bakersfield
    02 Tacoma
    I purchased new TG frame plates and steering box mount.
  14. Jan 27, 2014 at 8:46 AM
    Yia
    Yia [OP] Member
    Bakersfield
    02 Tacoma
    Got the coilovers mocked up. I need to figure a way to transfer the cab over in this garage. Any ideas?
    Driver Side
    Passenger Side
    Both
  15. Jan 28, 2014 at 1:57 PM
    99nmtaco
    Patrick
    NM / VA
    2001 4 Runner
    Haha dang moving that body over looks like its gonna be fun! Maybe just drop the new frame down as low as you can and slide the body over?
  16. Feb 4, 2014 at 8:40 AM
    Yia
    Yia [OP] Member
    Bakersfield
    02 Tacoma
    Boxed the frame and started mocking up the Chevy 63 in the rear. I decided to go with the RuffStuff Specialties 63" Chevy spring swap kit and the side mount shock brackets.
    Boxed the frame using the Trial Gear kit.
    For the Chevy 63 I moved the front hangers 7.5" forward and the rear shackle hangers in the original location.
    Chevy 63 mocked up.
    Welded the RuffStuff Specialties axle shock mounts.
  17. Feb 4, 2014 at 8:40 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Southern New Mexico
    2018 Tacoma TRD Off Road 4x4
    :eek:
    How did I miss this!? Haha
  18. Feb 9, 2014 at 11:33 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
  19. Mar 2, 2014 at 12:02 AM
    Yia
    Yia [OP] Member
    Bakersfield
    02 Tacoma
    Welded the rock sliders. Working on the last leg.
  20. Mar 17, 2014 at 9:33 PM
    Yia
    Yia [OP] Member
    Bakersfield
    02 Tacoma
    Old bent frame.
    I decided to plate the inside and outside of the frame with 3/16 steel to prevent the above from happening again.
