2002 Tacoma V6 Code P1135 Pinout for the F/A Sensor?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Blackwell99, Jan 3, 2017.
  1. Jan 3, 2017 at 4:51 AM
    Blackwell99
    Blackwell99 [OP] Member
    2002 Toyota Tacoma 4wd
  2. Jan 3, 2017 at 5:00 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    I like your approach, how you are trying to confirm the circuit is operating correctly before throwing money that parts. Not enough people do that before posting.
    On this forum is the factory service manual. It will have the wiring schematics for the engine electrical. You should find it in there. Try the ground first, you'll need to remove the glovebox to get to the Ecu plug to check the signal side.
    The Driver likes this.
  3. Jan 3, 2017 at 5:07 AM
    Blackwell99
    Thanks,
    I hate to ask but how do I find it? A general search of the forum does not find it?
  4. Jan 3, 2017 at 5:14 AM
    Caligula
    Los Angeles, CA
    It's stickied above.
    If you hook up the meter in series you should be able to see if the heater is functioning. You'll need to use something to simulate air flow. Using a OBD tool you can also see the raw voltage.
    The MAF heater is just there to keep the film at a set temperature. The air flow causing a drop in temp will result in an increase in voltage to maintain the temperature. The ECU measures the voltage drop as the level of air mass entering the system.
  5. Jan 3, 2017 at 5:34 AM
    Blackwell99
    Thanks
    I was just to going to check for voltage to the heater and coil restiance, that should tell the story. I just wade through than manual to find the pinout.
    Take care.
  6. Jan 3, 2017 at 5:38 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    if the sensor has over 100,000 miles on it and it is throwing sensor heater circuit
    it is 99.9999~% chance a real code. just go get an OEM sen$or (there is a updated P/N from the time your
    truck was new, the last digit changed) and install with new gasket
  7. Jan 3, 2017 at 5:43 AM
    Blackwell99
  8. Jan 3, 2017 at 10:44 AM
    Blackwell99
    Hi,
    Any thoughts on Aftermarket?
    Thanks
  9. Jan 3, 2017 at 11:24 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    aftermarket is ri$ky as the toyota ecu is extremely fussy and wants to see
    the exact waveform. if you go aftermarket get DENSO only
    and the exact replacement match for the toyota part number
    Blackwell99[OP] likes this.
  10. Jan 3, 2017 at 12:58 PM
    Blackwell99
    Thanks a lot.
    Looks like I'm stuck :)
    Autozone wants 170.00 for the Denso Part. Luckily you can find them cheaper
  11. Jan 3, 2017 at 1:41 PM
    Caligula
    Los Angeles, CA
    Do not buy aftermarket sensors. Ever.
    And fuck Autozone. Might as well go to the dealer. Try a local parts counter or even Napa. Where are you located?
    127.0.0.1 and Blackwell99[OP] like this.
  12. Jan 3, 2017 at 1:54 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
  13. Jan 4, 2017 at 6:12 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    I am with ya on this, but my denso a/f direct replacement on my 99 4runner has been solid
    a previous bosch I installed only worked for 200 miles after ecu reset, once ecu recalibrated
    it kept throwing codes. dumped it, went denso, all good
  14. Jan 4, 2017 at 6:18 AM
    Blackwell99
    Hi,
    New Orleans. I'm checking Ebay and Amazon. Napa wants the same 179.00 I like the idea of no sales tax though. :) The problem with Ebay is making sure you don't get scammed.
  15. Jan 4, 2017 at 11:12 AM
    Caligula
    Los Angeles, CA
    Go with Amazon. They will take returns no questions asked.
  16. Jan 4, 2017 at 6:28 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Yeah, Denso is the OEM of the sensor for Toyota. You just bypassed the 'Toyota' markup. The smart way to do it. :thumbsup:
