2003-04 Tacoma TPS
Discussion in '1st Gen. Tacomas (1995-2004)' started by beantown, Jun 27, 2014.
  1. Jul 27, 2014 at 8:52 PM
    jdkilroy
    jdkilroy Well-Known Member
    Jon
    Southern NH
    '02 4x4 SR5 Access Cab
    TPS for a 2002 3.4 is ~$46.00 from toyotapartszone.com
    You can go to that site and enter your vehicle's VIN and then look for the TPS under the electronic fuel injection section.
    Interestingly, there is no TPS listed for the 2004 DBL Cab, just a "relay computer" which is priced ~$50.00.
  2. Jul 28, 2014 at 7:00 AM
    beantown
    beantown [OP] Active Member
    They say that the TPS for a 2003 and 2004 3.4 is different than the pre-2003. I guess the Throttle body is different, and they don't sell the TPS for the 2003 and 04, you just have to drop 1300 bucks on a new TB, or just adjust it as I did, seems to still work fine...
  3. Jul 28, 2014 at 7:15 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    welcome to the party, hence why this post was created :D
    the TB for 03+ no longer has a separate IAC, and it is a drive-by-wire variant with a motor on the inside (firewall side) of the TB that sends data to the ECM/ECU
  4. Jul 28, 2014 at 7:18 PM
    jdkilroy
    Jon
    Southern NH
  5. Sep 27, 2014 at 4:08 PM
    Tacomajoe79
    Tacomajoe79 New Member
    joseph
    Reidsville nc
    97 regular cab 4wd
    15/12.5/33 tires 2" lift kit
    I have 97 2.7 reg cab with high idle and no power on the high end at all plenty of pedal but with wot it does nothing like I've hit a rev limit so I unplugged tps and was able to drive it? I could tell no difference at all other than check engine light?
  6. Sep 27, 2014 at 4:11 PM
    Tacomajoe79
    joseph
    Reidsville nc
    97 regular cab 4wd
    I was thinking truck should die or studded or something it ran as normal .....shitty
  7. Sep 28, 2014 at 3:43 AM
    2scars
    2scars Swollen Member
    Brandon
    RVA
    2003 TRD 4x4 Doublecab
    All-pro, T-G, Budbuilt, Warn, Tepui, Homefab rear bumper
    Tacomajoe, you may have a vacuum leak.
  8. Oct 5, 2014 at 4:52 PM
    squrrrlygurl
    squrrrlygurl Member
    Oakland, CA
    2003 4x4 SR5 DeChromed
    Debadged, Black Trim
    Hey all,
    I was having the same hesitation problem in my 03 V6 Tacoma...at 1500-2000RPM... I scoured the forums and am posting replies in the threads related to this problem because it may just be an easy fix for y'all as well, rather than replacing good parts
    this thread ...
    http://www.tacomaworld.com/forum/1st-gen-tacomas/168680-cant-figure-hick-up-out.html#post9264168
    suggested cycling the TPS with the engine off and pumping the accelerator 100 times..
    it totally worked!
    good luck!
  9. Aug 17, 2017 at 7:16 AM
    NM Lance
    NM Lance Well-Known Member
    Thread revival... Is this the correct 4-wire TPS??? I had to buy a new one recently and it looks identical, will this work in my '03 V6???
  10. Aug 17, 2017 at 7:19 AM
    NM Lance
    Sh!t, no it won't. Throttle twists the other way... Anyone want to buy a 4 pin 89452-22080? Uninstalled, brand new in box.
  11. Aug 17, 2017 at 2:21 PM
    tymbits
    tymbits Member
    Timothy P
    2004 Double Cab Tacoma TRD
    Bilstein 5100 w/ 883 Coils Dakar Leafs 285/75/16 KO2 ARB Front Bumper
    I have one from overseas that I ordered, they sent me 2. PM me if you want it and we can work out a price.
  12. Sep 9, 2017 at 7:52 PM
    Pauhana
    Pauhana Well-Known Member
    Mark
    Irvine, CA
    04 SC PreRunner
    RECARO Trend Seats TRD SC URD Fuel Upgrades
    Do you still have the extra TPS for sale? If you do i'm interested in buying it from you. I did PM you.
  13. Sep 10, 2017 at 2:36 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    What company did you buy it from and was it the correct one?
  14. Oct 24, 2017 at 8:02 PM
    Baghira
    Baghira New Member
    2003 Toyota Tacoma
    I've just pulled the TPS off of my `03 Tacoma and have been getting COMPLETELY skunked on finding a replacement until-- with the help of a couple of very determined parts counter guys-- we found out that the 4- prong TPS that's been on my pickup since it rolled out of the factory appears to be physically IDENTICAL (4 prong connector and all) to the TPS off of a mid/late 1990's Toyota CAMRY.
    Yeah... I know... "CAMRY?!?!"
    It's like finding out that your anvil has a uterus.
    However... I'm going to get one and see if it will work. Sometimes odd parts get used at first and then never get listed properly.
    93-96 Toyota Camry TPS. I've worked on enough old Japanese motorcycles to know that the TPS for the mid 90s Camry (shaking my head in disgust) may very well work just fine.
  15. Oct 24, 2017 at 8:04 PM
    #35
    Baghira
    Baghira New Member
    2003 Toyota Tacoma
    PS: The TPS off of the Camry also appeared to be THE ONLY TPS that was actually, physically IDENTICAL to the one that came off my Taco.
    Fingers crossed!
  16. Oct 24, 2017 at 8:08 PM
    #36
    gumbo-taco
    gumbo-taco Well-Known Member
    NC
    2004 DC Offroad
    This is where my search ended, too. I just haven't persued it further. Very interested in what you find. Keep us posted. I know @mechanicjon would he interested as well
  17. Oct 25, 2017 at 1:07 AM
    #37
    mechanicjon
    Jon
    Scottsdale Arizona
    Which part number did you order. I've cut 3 different ones apart that looked identical on the outside. Inside they weren't even close.
  18. Oct 25, 2017 at 11:02 AM
    #38
    Baghira
    Baghira New Member
    2003 Toyota Tacoma
    I'll keep you posted on what I find out. Just for kicks, I went to the local Megafortress Of Toyota Worship (dealer) and the manager of the parts/service center took the time to explain very thoroughly WHY the part I'm looking for isn't sold individually. It allegedly has something to do with the engineer's perception of the evolution of the actual engineering of the vehicles themselves, VS the engineer's "faith in the abilities of the technicians" to repair the vehicles if something goes wrong with that particular component.
    There was a lot of technical jibber-jabber but what it all pretty much boiled down to was that for my particular model/year of Taco, I'm almost certainly facing one of a few options...
    1) For a cheap repair, do what my dad would do, and scour the wrecking yards for that part and pay a ridiculously high price for a non-returnable electronic part that has zero guarantee of functionality.
    OR....
    2) Pony up the bucks for the whole throttle body replacement routine and know that you've got an actual fix with BRAND NEW PARTS that come with warranties and such, and not have to worry about that particular item for quite a while.
    OR...
    3) Take a gamble on the Camry part, screw it on, plug it in, and see if it works.
    I'm going to pursue option 3, first. If that doesn't work, I'll bite the bullet and follow option 2.
    A question for mechanicjon: I don't suppose you have any pictures of what you found when you cut the three visually-identical-but-defiinitely-different-on-the-inside apart, do you? I'd be really interested in seeing what you found.
  19. Oct 25, 2017 at 11:13 AM
    #39
    Baghira
    Baghira New Member
    2003 Toyota Tacoma
    As I understand it, the issue is also linked to the Vehicle Stability Control (?) System, which was supposed to help control throttle inputs if/when the VSCS detected that the rear wheels were spinning, or the vehicle might be in a skid/slide situation. This alleged VSCS is also supposed to start alarming (beeping) if/when it detected the vehicle might be in an unstable situation.
    My Taco has never once beeped at me in the entire time I've owned it over such things. I've had the tires spinning. I've drifted corners with it. I've been on bumpy-ass washboard roads with it. I've done cookies in the snow with it. I've even had it completely airborne once (unintentionally, courtesy of too much speed on a strange road, at night over a poorly marked railway crossing. Whoops. Yeee-haw? It didn't go very high, but the person following me verified that I was absolutely, momentarily "in the sky".), and never ONCE has that truck "beeped" at me. I didn't even know it was able or supposed to do so.
    It might explain the mysterious, frantic, panicky beeping of a adorable little Toyota rental car that I had a few years back in St. Louis, MO, (but that's a story for another time).
  20. Oct 25, 2017 at 11:21 AM
    #40
    mechanicjon
    Jon
    Scottsdale Arizona
    That I know of only the 4runners have the VSCS. I'll take some pictures of the TPS's. What I've found is that they all had an idle position that was either open or closed and one sweep circuit. Instead of two sweeping circuits in our TPS's.
