2003 3.4 good and bad for first gens
Discussion in '1st Gen. Tacomas (1995-2004)' started by vtragweed, Jan 1, 2011.
  1. Jan 1, 2011 at 2:42 PM
    vtragweed
    vtragweed [OP] Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    im gonna trade in my 2008 2.7 for a 2003 3.4 double cab trd, what are the ups and down for the first gens.
  2. Jan 1, 2011 at 3:01 PM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    dependable. if you already have your mind set on trading your truck in for a first gen, nothing we say will make you change your mind. i love my 03 dc trd and there are no problems.
  3. Jan 1, 2011 at 3:36 PM
    747 function > form
    1st Gen.
    1. weak leaf springs (solution: replace/add-a-leaf/traction bar)
    2. frame rust (solution: replace frame)
    3. tokico shocks and struts, but yours may have billies (solution: replace)
    These are all I'm aware of and, fwiw, they're easily identified. '03 DC TRD, ftw!
  4. Jan 1, 2011 at 3:44 PM
    clarkie152
    MA
    2016 4Runner Trail
    pretty sure the recall for the frame rust recall has expired. all these issues though are ones that come with any vehicle you buy at this age.
  5. Jan 1, 2011 at 3:47 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    i thought frame rust was 15 years from production? for a 2003 wouldn't that mean 2018?
  6. Jan 1, 2011 at 3:54 PM
    clarkie152
    MA
    2016 4Runner Trail
    if you had already had it inspected prior to 10/31/10. they then guarantee it after it is inspected.
  7. Jan 2, 2011 at 11:34 AM
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    3.4l is very dependable. That is why I love this truck. I never had to worry about it breaking down. I am OCD on maintenance so I change the oil every 3k miles with full synthetic.
    In a year I will be selling it though. :( Will be buying a 2012 Toyota 4runner TE.:D
  8. Jan 2, 2011 at 12:31 PM
    pittim
    pittim mittip backwards
    Pittsburghish
    Mk7 Oil Burner
    Permanent CEL
    it'll have tokicos if it still has stock suspension (all first gen TRD DCs (maybe SR5s too?) came with tokicos)
    OP, there really isn't much to go wrong. theres only one tsb for them, which is lower ball joints. you can look up the vin on the toyota owner site to see if it was done.
    other than that, the frame recall is really the only common problem with them.
  9. Jan 2, 2011 at 2:02 PM
    jcremeans11
    jcremeans11 Well-Known Member
    Jon
    Ohio
    01 Tacoma SR5
    Spectre Cold Air Intake, Michelin XLT's (265/70/16), Escort Solo S3, Grounded Throttle body
    Well for the frame rust, ask the owner if the frame has been sprayed. If not then go to a Toyota dealership and get it sprayed yourself.
    Power wise, you'll probably see a little increase, not much due to the mods you've done to your 2.7.
    The biggest pro is that the 03 will most likely be on the road years longer than your 08 will. Just because of the quality that the 1st gens are made with.
