2003 4Runner Limited 4wd V8 FJ tcased overlanding rockcrawling do-it-all build
Discussion in '4Runners' started by xtremewlr, Feb 8, 2020.
  1. Oct 3, 2020 at 5:39 PM
    #241
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    But... does it do 4x4 burn outs?
  2. Oct 4, 2020 at 10:08 AM
    #242
    xtremewlr
    xtremewlr [OP] Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    It didn't do them before. But it will in the dirt!
    Empty_Lord[QUOTED] likes this.
  3. Oct 4, 2020 at 3:55 PM
    #243
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Fuck wiring.
    Got the 4WD (using the 4Runners Center Diff Lock indicator for this) and 4LO dash indicators wired up. What a pain in the ass. I should have extended the wires off the tcase switches before putting it under the truck. But it's done now, used weatherpac style connectors too.
    Had to do the tcase weatherpac connector twice because one of the wires broke after the install.
    Post 116 has the wires for the indicator lights - https://www.tacomaworld.com/threads...er-limited-4wd-v8.651589/page-6#post-23847791
    Kwikvette likes this.
  4. Oct 5, 2020 at 7:13 PM
    #244
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    New tires on today. Toyo Open Country A/T III in 285/70x17. 5 tires so I have a spare.
    Not a huge difference is height, but it counts!
    About the same width. The side by side it looks wider but here they look pretty close.
    Spare tire lives here for a while, until I can build a new bumper with tire carrier. 285/70 just doesn't fit the stock location. Hits the frame al the back where the tow hitch is and hits the frame and tracbar going forward.
  5. Oct 7, 2020 at 5:53 PM
    #245
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Alignment done today. Really surprised, they didn't have to make any adjustments. No idea when the alignment was done prior, this is the first one I've had done since I bought it. After swapping out all the suspension stuff from the collapsed XREAS and the rear links, I figured it would have been off a little.
    04Pre_Runner, Empty_Lord and Phessor like this.
  6. Oct 7, 2020 at 8:12 PM
    #246
    Empty_Lord
    Dan
    youre running stock upper control arms right? lifted i like to shoot for 2.0-2.5 castor just for tire clearance.
  7. Oct 7, 2020 at 8:41 PM
    #247
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Yeah, front suspension is essentially stock still.
  8. Oct 7, 2020 at 8:42 PM
    #248
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    I had minor rubbing at full lock on the front of the wheel well, just on the plastic fender liner. So I cut that shit off.
    Empty_Lord likes this.
  9. Oct 7, 2020 at 8:45 PM
    #249
    Empty_Lord
    Dan
    Totalled
    xtremewlr[QUOTED][OP] likes this.
  10. Oct 7, 2020 at 8:46 PM
    #250
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    No, I won't sell it.
  11. Oct 7, 2020 at 8:46 PM
    #251
    Empty_Lord
    Dan
    Was it a rollover? No? Not interested! :rofl:
  12. Oct 7, 2020 at 8:47 PM
    #252
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    :rofl::rofl:
  13. Oct 7, 2020 at 8:54 PM
    #253
    ROlla-Xrs
    ROlla-Xrs Well-Known Member
    Roman
    Elk,WA
    1st gen Trd Tacoma
    Thats a lot of jack and stands:D
  14. Oct 7, 2020 at 8:56 PM
    #254
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Tire shop, so :notsure:
  15. Oct 8, 2020 at 4:22 PM
    #255
    Kwikvette
    Fresno County
    4 run, 2 don't
    This forum is for Tacoma's.
    Fight me :luvya:
    xtremewlr[OP] likes this.
  16. Oct 8, 2020 at 4:48 PM
    #256
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    :rofl::rofl:
    And.... this IS the 4Runner forum. For rehabilitated Tacoma owners. :rofl:
    Empty_Lord and Kwikvette[QUOTED] like this.
  17. Oct 8, 2020 at 4:54 PM
    #257
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Just installed 3 of these guys into the washer hose system. I was having problems with no fluid being in the hoses if I didn't use them for a while. So it was draining back into the reservoir or maybe the pump is going bad. But, I'll see if these check valves help any, especially with the rear window washer.
    Toyota part # 8532126020
    jubei and 04Pre_Runner like this.
  18. Oct 9, 2020 at 3:10 PM
    #258
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Burned in the passenger side Heavy Duty LCA frame braces from Marlin. Got the kit back in February when they were on sale. Finally installing them. :rofl:
    https://www.marlincrawler.com/axles/front-axle-armor/hd-lca-frame-brace-2003-2009-4runner
    These also add protection to the alignment cam tabs. They can be installed with the suspension in place, it just makes it a little trickier unless you have a lift. Which I don't.
    Driver side gets done tomorrow, so that is the before pic.
    Welding the front brace in on the passenger side.
    And finished.
    I also did an oil and filter change today before starting on this little project.
  19. Oct 9, 2020 at 4:25 PM
    #259
    Phessor
    Phessor Well-Known Member
    Looks good, I'm waiting for the 1st Gen kits...
  20. Oct 9, 2020 at 4:54 PM
    #260
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    They are on pre-order status now, so hopefully they have them soon.
    Phessor[QUOTED] likes this.
