2003 4Runner Limited 4wd V8 FJ tcased overlanding rockcrawling do-it-all build
Discussion in '4Runners' started by xtremewlr, Feb 8, 2020.
  1. Feb 7, 2021 at 8:06 PM
    #381
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    It ain’t too hard to weld aluminum...
  2. Feb 7, 2021 at 8:10 PM
    #382
    xtremewlr
    xtremewlr [OP] Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    I'd like to get setup for it eventually. Tig would be nice but I think you can wire feed, like MIG, aluminum, right?
  3. Feb 7, 2021 at 8:10 PM
    #383
    Empty_Lord
    Dan
    Probably. I tig it all
    xtremewlr[QUOTED][OP] likes this.
  4. Feb 7, 2021 at 8:16 PM
    #384
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Interesting design with the modular wings, I dig it. I had issues with the swing out mount flexing and had to go back a few times to reinforce and brace it, yours is much lower and closer to the mount(s) so that should help with that.
    xtremewlr[OP] likes this.
  5. Feb 7, 2021 at 8:43 PM
    #385
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Yeah, I decided to go this route to make it easier if I need to do work on the corners for whatever reason. Like moving the body mounts higher! Also makes it easier to fix them if they get beat to shit.
    I've though about flex from the swingout since I had that issue with the Coastal rear bumper on my old Tacoma. I'm hoping I don't have any problems with it on these but I have a couple places I can add more reinforcement on the passenger side if need be.
    If I ever redo these wings, I'll move the single, main bumper bolt to the back side of the main bumper so it's hidden. That would open up the corners for a little better design I think, instead of leaving them un-finished looking like now. But I'm happy with them as they are for now.
  6. Feb 7, 2021 at 8:52 PM
    #386
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Happy that's it's looking more *finished* again! Even if it isn't. Really need to get a lift kit for it, that heavy ass front bumper probably ate up about an inch in front. Even just stiffer springs would be better. Eventually....
    I also reinstalled the driver side lights from the old running boards. For now, they are just puddle lights but I'm going to wire in a switch and get better LED lights to make the rock/camp lights. I just re-used the metal housings and lights from the OEM running boards and installed LED bulbs for now. Still have to do the passenger side.
    jubei, Phessor, y=mx+b and 1 other person like this.
  7. Feb 8, 2021 at 4:51 PM
    #387
    Roody
    Roody Well-Known Member
    Ross
    SW CT
    GX460
    That looks killer, well done
  8. Feb 8, 2021 at 5:39 PM
    #388
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Thanks!
  9. Feb 8, 2021 at 6:29 PM
    #389
    Roody
    Ross
    SW CT
    GX460
    If I ever make it out to AZ I might ask you to build me one :D
  10. Feb 11, 2021 at 7:49 PM
    #390
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Making some extremely slow progress on the swingout. Trying to work on it a little during the week, since I will be out of town this weekend.
    Wishbone Runner, jubei, Roody and 3 others like this.
  11. Feb 14, 2021 at 8:07 PM
    #391
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Was out of town for the weekend, visiting family in San Diego. Made a pit stop at Buckman Springs off I-8 on the way home today.
    jubei, Kwikvette, Roody and 2 others like this.
  12. Feb 15, 2021 at 2:17 PM
    #392
    Kwikvette
    Fresno County
    4 run, 2 don't
    That bumper though :drool:
  13. Feb 17, 2021 at 8:39 PM
    #393
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Hit the 300k mark today, right when I turned to back into my garage.
    MohoMan, Roody, y=mx+b and 2 others like this.
  14. Feb 20, 2021 at 8:47 AM
    #394
    Kwikvette
    Fresno County
    4 run, 2 don't
    That swingout tho :tumbleweed:
  15. Feb 20, 2021 at 8:57 PM
    #395
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Yeah, got some major work done on it today.
    Capped the corner and glued on the swing lock thingy.
    Also glued on the hinge plate for the latch system. Both the swingout hinge and the latch system are from 4xInnovations. Highly, highly recommend these, they are stout! :muscleflexing:
    Figured out and glued on the catch pin for the latch.
    Had to grind off a bit of the pin to clear the hatch opening. Plenty of room now. I ground some more after this pic BTW...
    Got the carrier uprights figured out. Went to get steel this morning but they didn't have any 2x3 rems, which is what I had originally planned on using. So I got some .120 wall tube instead.
    Nice and tight (as tight as I will go, gotta have some gap!) to the hatch.
    Braced it. Ignore the ugly, shitty welds, thank you very much. :anonymous:
    And lastly, glued on the whatchamacallit thingy to hold the tire. I have a 1/4" plate that I need to drill mounting holes in and glue to the whatchamacallit thingy still.
    And here it sits until I can finish it off tomorrow. Mostly. Have more stuff I want to do but don't have the time right now.
    Test fit of the spare to get a rough idea of where it will sit finally.
    Phessor, Roody, jubei and 2 others like this.
  16. Feb 21, 2021 at 8:17 PM
    #396
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Done. At least for now. It's functional but there's a few more thing I would like to do to it. Good for now tho, I have a wheeling/camping trip next weekend.
    Mounted the wheel plate and gave it a happy 2.5 inches.
    It doubles as a bottle opener. Low Range sells them.
    Got busy and didn't take a lot of pics. Glued together what will eventually hold a jerry can or 2. Might see what else I can do with the extension. Plate is mounted there for now.
    Ran out of paint initially so only was able to paint a few pieces. Reinstalled the passenger plastic bumper cover. I made everything fit so that the swingout hinge bolt is covered by the bumper cover. Keeps it clean looking.
    Spare tire mounted.
    Fully open in the locked position.
    Lots of room for that hatch to open.
    Ran some errands and picked up more paint. No rattles or anything from the swingout. Rock solid back there with the 4xInnovations hinge and latch system.
    Glad to be done with this for a while!
    jubei, Phessor, Roody and 2 others like this.
  17. Feb 22, 2021 at 6:12 AM
    #397
    Roody
    Ross
    SW CT
    GX460
    Any plans to make/sell them?
  18. Feb 22, 2021 at 7:30 AM
    #398
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Nope, not at all, sorry.
  19. Feb 22, 2021 at 7:31 AM
    #399
    Phessor
    Phessor Well-Known Member
    Bob
    1998 TRD XTra Cab
    Stuff
    That looks really good, great job!
  20. Feb 22, 2021 at 7:38 AM
    #400
    y=mx+b
    y=mx+b Station Wagon
    Lafayette, IN
    '05 T4R SR5 v6 4wd
    You killed it dude, looks awesome! I really like how low profile the rear turned out. I always disliked how most 4th gen off-the-shelf options are really blobby on the sides, but your bumer-ette pieces hug really nicely. I didn't see it, but you didn't have to cut or mash anything in the vent areas/behind the cover on the side to get them to tuck nicely, right?
