2003 double cab 4x4 212k for $7500?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trucksandbikes, Jul 7, 2020.
  1. Jul 7, 2020 at 10:48 AM
    Trucksandbikes
    Trucksandbikes [OP] Active Member
    Oregon
    2020 trd sport
    Hey y'all!
    Looking to get some advice on a truck I'm looking to buy.
    its 2003 double cab 4x4
    212k
    Asking 8500 but got him down to 7500
    I'll post a picture of their description.
    It has had rust but the guy has wire brushed the frame and patched it back up.
    Also the ebrake doesn't work, needs an o2 sensor and the sqeeels when the ac come on.
    What do you think is this worth it?
    Thanks!!
    F94FA3F9-964F-4AE2-85F1-BF269008E633.jpg 83526DF0-712C-4691-8F66-B37D919E645D.jpg 641FFFC7-4C07-4574-A34D-AFCA05B75021.jpg C8FF507F-855F-4559-9437-B9A41539F075.jpg 0D526046-B2EE-4DAF-857C-9C2517E5722C.jpg
  2. Jul 7, 2020 at 10:51 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Pics of frame?
  3. Jul 7, 2020 at 10:54 AM
    jruiz555
    jruiz555 Well-Known Member
    lot of corrosion on the motor itself, i can see the brake lines, and cables being messed up
    RyanL likes this.
  4. Jul 7, 2020 at 11:01 AM
    Tacotruck7
    Tacotruck7 Well-Known Member
    SoCal
    04 Prerunner Dbl Cab 2.7L
    That's a good deal for 7,500. I would buy it in a heartbeat if its in as good of condition as the description says.
  5. Jul 7, 2020 at 11:15 AM
    Trucksandbikes
    Oregon
    2020 trd sport
    I don't have any pics of the frame other than what I posted.
    How much do you think o2 sensor, fixing the squeeling and ebrake would be to fix?
  6. Jul 7, 2020 at 11:15 AM
    Trucksandbikes
    Oregon
    2020 trd sport
    Would this maybe lead to the ebrake not working?
  7. Jul 7, 2020 at 11:16 AM
    Trucksandbikes
    Oregon
    2020 trd sport
    It's from Wisconsin.
    How worried should I be about rust??
  8. Jul 7, 2020 at 11:21 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard new member
    Rust is an issue in snow states
  9. Jul 7, 2020 at 11:28 AM
    Trucksandbikes
    Oregon
    2020 trd sport
    If it's been brushed and painted shoul less worried?
    Also how mush rust is tooo much rust???
  10. Jul 7, 2020 at 11:28 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    You really need to confirm it youself, or get some very detailed pics of lots of areas of the frame: FR and RR attachment points for the rear springs; long sections under the cab (both sides); and the rear of the front wheel openings/torsion bar bushing attachment points.
    That rear section of the wheel opening, the frame gets pounded by rocks picked up by the tire when turning on gravel roads. Aggressive tread tires of course make it more likely to occur. Paint and ED coat don't stand a chance, and rust begins.
  11. Jul 7, 2020 at 11:32 AM
    Black DOG Lila
    Virginia
    Taco frames rust from inside out.
    Paint may look good until hit with hammer which is how you test frames for rust
    ToyoTaco25 likes this.
  12. Jul 7, 2020 at 11:42 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Do some research on tacoma frame rust, and the extent of potential damage.
    Then ask yourself if simply using a wire brush and painting is "enough"...
    According to Toyota, "too much" rust was something like a dime sized hole in the frame.
    When you go to look at it, take a hammer with you. Tap around on the frame and listen for a change in the sound. It should be a nice bright "tink" sound. If you get to spots where it's more of a dull thud, that means you have frame cancer, and should likely walk away.
    These frames, for the most part, rust from the INSIDE out. If all the seller did was take a wire brush to parts, you can guarantee he didn't do anything inside the frame.
    Those frame patches pictured aren't going to do squat. You might as well just put some tape over them. I would be highly suspicious.
  13. Jul 7, 2020 at 11:43 AM
    Trucksandbikes
    Oregon
    2020 trd sport
    thanks I'll try to get more pictures. Other wise going to look at it tomorrow. It's 4 hours away so kinda a trek.
    what do you think of the patches area by the rear wheels?
  14. Jul 7, 2020 at 11:45 AM
    Trucksandbikes
    Oregon
    2020 trd sport
    That's what we're planning on doing with the hammer.
    We are going to be taking it out to Oregon. So it kinda feels like shooting ourselves in the foot with the rust. but 4 door tacos are like 10k out here.
  15. Jul 7, 2020 at 11:53 AM
    Jguardino
    Jguardino Well-Known Member
    jacob
    209
    01 Dbl cab, 22 TRD OR PREM
    35's huh? body lift?
  16. Jul 7, 2020 at 11:56 AM
    Black DOG Lila
    Virginia
    There are frame caps made specifically for Tacomas.
    The passenger side patch is a hack job on a critical area thar supports shock absorber. Patch just covers hole.
    Here's a pic of same shock mount from back of frame with no rust through showing from outside of frame.IMG_20200419_111719027.jpg
  17. Jul 7, 2020 at 11:58 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    35s? Weighed down? Shade tree patches on the frame? Salty climate?
    I wouldn't touch this thing at any price
    Jguardino likes this.
  18. Jul 7, 2020 at 12:03 PM
    Jguardino
    jacob
    209
    I would like to know how hes running 35s. when i bought mine the dude had a 3" body lift just to fit them before i removed both. also those springs are shot
    I would wait for a better taco with lower miles and less rust for that kind of money
  19. Jul 7, 2020 at 12:05 PM
    Masshole_And_His_Taco
    Masshole_And_His_Taco RIP Rick
    Northish South Shore MA
    Two-seater Curb-eater
    Little bit of stuff.
    Judging by the clearance between the bed and frame, the most it could have is a 1" body lift since the bed and body seems to be properly aligned (ruling out a cab only lift)
    Jguardino[QUOTED] likes this.
  20. Jul 7, 2020 at 12:05 PM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    The amount of rust on the steel bolts etc. under the hood raise a red flag for me. The frame seems to show well at first glance, but a frame that nice won't have those mickey mouse patches in the passenger rear wheel well. I'd be pretty worried.
