2003 Off Road Diff Oil?
Discussion in '1st Gen. Tacomas (1995-2004)' started by itsmebags, Apr 10, 2020.
  1. Apr 10, 2020 at 3:41 PM
    itsmebags
    itsmebags [OP] Well-Known Member
    Germantown, NY
    2003 Green Tacoma TRD Off Road
    Going to change my rear/front diff and transfer case oil. Think I need 75-90 for all 3. Only question is do I use the non slip oil? Most of the oil is synthetic 75-90 but I read somewhere that I needed to use 75-90NS (non slip). Is this correct?
    Truck is also an automatic if that matters. Thanks!!!
  2. Apr 10, 2020 at 3:47 PM
    StillNoPickles
    StillNoPickles Well-Known Member
    2020 RAV4 Hybrid LE
    Does it have limited slip? If so, than a 75w-90 with friction modifier. Many oils will come with it, just be sure to check the labeling. If it’s an open diff, you can run any 75w-90 in their trouble-free. On my first gen I used Delo 75w-90 or Supertech every 30k with good results.
  3. Apr 10, 2020 at 3:48 PM
    itsmebags
    Germantown, NY
    Got to admit, pretty ignorant with if it's a limited slip or open or not or whatever! If someone could advise to how to I can figure that out I would be appreciative.
  4. Apr 10, 2020 at 3:49 PM
    StillNoPickles
    2020 RAV4 Hybrid LE
    TRD offroad with rear locker correct? If so, you’ve got an open rear diff.
  5. Apr 10, 2020 at 3:52 PM
    itsmebags
    Germantown, NY
    Yes, it's a TRD offroad. Has the rear diff button by the steering wheel. Sorry, if I am clueless on this!
    whatstcp likes this.
  6. Apr 10, 2020 at 3:57 PM
    itsmebags
    Germantown, NY
    Sounds good!
  7. Apr 10, 2020 at 6:30 PM
    itsmebags
    Germantown, NY
    Should I keep it conventional or is synthetic ok??
  8. Apr 10, 2020 at 8:58 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Syn is fine.
  9. Apr 11, 2020 at 4:45 AM
    itsmebags
    Germantown, NY
    Sounds easy enough!
  10. Apr 11, 2020 at 8:50 AM
    Jeeperwilly
    Jeeperwilly Well-Known Member
    NE Minnesota
    03 X-cab 4x4 TRD
    If it's your first time doing this, take the filler off first. Nothing worse than pulling the drain plug and the fill plug is siezed.
  11. Apr 11, 2020 at 9:41 AM
    itsmebags
    Germantown, NY
    Believe it or not I’m more capable of changing it than finding the right oil
    0xDEADBEEF likes this.
  12. Apr 11, 2020 at 9:41 AM
    itsmebags
    Germantown, NY
    I ended up going 75-90 for the transfer and front. Found in the manual that it calls for 80-90 in the rear.
  13. Apr 11, 2020 at 9:55 AM
    Jeeperwilly
    NE Minnesota
    03 X-cab 4x4 TRD
    No worries, just trying to share learned failures.
  14. Apr 11, 2020 at 10:58 AM
    itsmebags
    Germantown, NY
    Much appreciated! I read that somewhere as well so you weren’t the only one!
  15. Apr 11, 2020 at 10:58 AM
    itsmebags
    Germantown, NY
    Haven’t done it yet. Oil change is due in a week or a few hundred miles and then I’ll just do them all then. Oily day!
    whatstcp[QUOTED] likes this.
