2003 tacoma alarm issue.
Discussion in '1st Gen. Tacomas (1995-2004)' started by mtxsub, Jun 24, 2012.
  1. Jun 24, 2012 at 1:21 AM
    mtxsub
    mtxsub [OP] Well-Known Member
    tacoma prerunner
    sound system led lights
    Ever time i use my key to open my door on my truck the alarm goes off. Any one know a way to fix it?
  2. Jun 24, 2012 at 1:45 AM
    mtxsub
    tacoma prerunner
    battery is good cleaned the terminals works fine. I think it's the alarm system that is acting up the only way to get in the truck is by the remote.
  3. Jun 24, 2012 at 10:15 AM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    Your door lock cylinder has an electrical switch in it, and the alarm has current sensing. The alarm is working the way it's supposed to work.
    Why would you want to unlock a door with the alarm on anyhow? Is there something special you're trying to do?
  4. Jun 25, 2012 at 10:41 AM
    mtxsub
    tacoma prerunner
    Ok lets say i only have the key to my truck no remote and i put the key in the door to unlock it. The alarm will go off why would it go off when i'm using the key?
  5. Jun 29, 2012 at 1:35 PM
    dirtJMW
    dirtJMW Member
    joel
    VA
    2003 Tacoma V6 TRD
    is it an aftermarket alarm system?
    I had one, I disabled the horn of the alarm...there should be an re-set button, turn the key halfway while holding the button until the alarm shuts off.
