2003 Tacoma Complete Front Hub Assembly
Discussion in '1st Gen. Tacomas (1995-2004)' started by Stasis, Dec 29, 2019.
  1. Dec 29, 2019 at 1:34 AM
    Stasis
    Stasis [OP] Member
    Is there nowhere to get a completely assembled 2003 Tacoma front hub? I see some options for 2005+ but nothing other than unassembled parts required a press for 1st gens.
  2. Dec 29, 2019 at 5:12 AM
    Balockay
    Balockay Well-Known Member
    Blake
    Cleburne, TX
    2017 4Runner TRD ORP
    Just look at the build thread
    The bearing presses into the spindle and then the hub presses into that. Even if there was a complete assembly, it would be super expensive. Much cheaper to either buy a press and do it yourself or pay a shop to press them in and out for you.
  3. Dec 29, 2019 at 8:40 AM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    Like @Balockay said, it presses into the spindle. The second gen units bolt into the spindle. If you really want an assembled unit like second gens, go grab a whole spindle from pick n pull. Ive done it when a press wasnt available.
